Browse Forums Kitchen Splashbacks Re: Splashback requirements - Australian standards????? 26Mar 22, 2023 5:08 pm renomart Here is some info from the HIA... There is some confusion as to what wall materials can be used behind gas stovetops where there is a requirement to have a fire resistant (non-combustible) surface. Essentially one of the two wall materials used – either the wall lining or the splashback (if installed) - must be non-combustible if they are within the minimum distance to the gas burner. AS 5601:2004 – Gas Installations requires that if the distance is less than 200mm from the periphery of the nearest burner to any vertical combustible surface or vertical combustible surface covered with toughened glass or sheet metal, then the vertical surface needs to be protected to ensure the surface temperature of the combustible surface does not exceed 65oC above ambient. This protected area must cover a minimum 150mm above the hob. Confusion has arisen as to what is a non-combustible material because the Building Code of Australia (BCA) provides the general construction requirements for walls in any building. This concession is overridden by the gas & plumbing requirements for new buildings, adopted in each State and Territory – being AS 5601:2004 – Gas Installations. More info for walls behind gas stovetops Hi, so HIA is the right Association to talk with in case we need to comply a stone product with Australian fire standard for splashbacks? Thank you Re: Splashback requirements - Australian standards????? 29Mar 28, 2023 12:09 pm alexp79 wouldn't any stone be fire retardant? a real stone would, but engineered stone isn't actually a real stone. probably good example of why the certificates are required, just because marketing gives something a common name, doesn't mean that this something will inherit all the properties. Building Standards; Getting It Right! What exactly do you need to know? Plywoods are graded from A to D for their faces. A and B are generally high quality that would be used for furniture. Both faces can be… 1 445 1 3809 You can ask the plumber to run 2 pipes to you laundry. One connected to the mains and one to the tank ( i did this in my home) I find that if you just turn your pump off… 6 6797 |
