Browse Forums Kitchen Corner Re: dishwasher plumbing dilemma 12Jan 15, 2010 11:04 pm 3 legs to stand on actually..., you must be his friend...He well knew what I wanted and he well knew what is correct and what isnt. I don't think a tempering valve is the answer..he should have used the cold supply...it was his mistake, he should fix it.So, I havent paid the bill yet...another tradie tries to deceive me, (gratis, ha ha) Re: dishwasher plumbing dilemma 13Jan 18, 2010 7:53 am camelia 3 legs to stand on actually..., you must be his friend...He well knew what I wanted and he well knew what is correct and what isnt. I don't think a tempering valve is the answer..he should have used the cold supply...it was his mistake, he should fix it.So, I havent paid the bill yet...another tradie tries to deceive me, (gratis, ha ha) i've been thinking about this post all weekend and after re reading your origional post came to the conclusion that 1. your pipes are installed the wrong way 2. whoever has placed the pipes this way has welded the connection for the dishwasher onto the hot water pipe 3.the plumber you have contracted to fit the connection has seen the existing t junction and has conected to this . So really the plumber has only extended the services that you have supplied to him . because you havnt been specific and told him that the connection was on the wrong pipe what was he to do ,run the water to find out if what you have supplied was correct ,no he connected to your fittings in good faith . its like asking a carpenter to come around and fit a door ,you already have the opening but you want the carpenter to feel around the wall and say that your door is in the wrong place and should be somewhere else you neglected to mention that you hadnt paid the plumber so you already have leverage over him so why come here to ask ,why not just ring the plumber to tell him YOUR problem and let his professionalism handle the rest . i think you should be finding and contacting the origional plumber that did the work to come back and correct his mistake ,but no that wont happen he's been paid ! Re: dishwasher plumbing dilemma 14Jan 18, 2010 9:28 am For clarification. He's the original plumber whom nearly 3 months ago I have paid and who initially installed and soldered the pipes the wrong way...hot where cold is and vice versa...he soldered the dishwasher tap T junction to the hot pipe (he installed the hot pipe back to front) whilst I was at work. He hasn't shown much professionalism....i.e; coming to my house to install the sink taps without the correct pipe connectors etc. to connect to the pipes he had initially installed, then sending me to the hardware store to find them; then charging me for 45 mins time he spent at tradelink getting flexible hoses for the gas pipe that he forgot to bring to the job with him to connect to the gas pipe he had installed previously Hmmn. me thinks his mind was on another job...he was in too much of a hurry to get to another job he booked without finishing the job he'd agreed to do that day ie, installing a new HWS. I took time away from work to be at home that day, now I have to take more time off. He has to come back anyway, he said to pay him when the work was finished. Re: dishwasher plumbing dilemma 15Jan 18, 2010 9:49 am camelia For clarification. He's the original plumber whom nearly 3 months ago I have paid and who initially installed and soldered the pipes the wrong way...hot where cold is and vice versa...he soldered the dishwasher tap T junction to the hot pipe (he installed the hot pipe back to front) whilst I was at work. He hasn't shown much professionalism....i.e; coming to my house to install the sink taps without the correct pipe connectors etc. to connect to the pipes he had initially installed, then sending me to the hardware store to find them; then charging me for 45 mins time he spent at tradelink getting flexible hoses for the gas pipe that he forgot to bring to the job with him to connect to the gas pipe he had installed previously Hmmn. me thinks his mind was on another job...he was in too much of a hurry to get to another job he booked without finishing the job he'd agreed to do that day ie, installing a new HWS. I took time away from work to be at home that day, now I have to take more time off. He has to come back anyway, he said to pay him when the work was finished. well then thats good "alls well that ends well" Re: dishwasher plumbing dilemma 16Jun 01, 2010 9:58 am The plumber put the 'tee' fitting on the cold tap and now the dishie runs off the cold...I'm happy about that...it may sound picky but ever since that fitting was placed the water pressure has dropped quite significantly...I guess it's not that much of a problem...just takes a longer time to fill the sink...any ideas why the pressure dropped? Re: dishwasher plumbing dilemma 20Jun 01, 2010 4:25 pm Borg is probably right. Take the aerator off the end of the spout and clean it out. You probably got some muck through the lines when the plumber did his work and it has blocked the aerator/flow restrictor. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2904 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6395 Hi Sillysausage1900, Hope all is well. I came across this forum as Im somewhat same situation with you regarding Roof Plumbing certificate requirement. Im requesting a… 4 9652 |
