Browse Forums Kitchen Corner Re: dishwasher plumbing dilemma 16Jun 01, 2010 9:58 am The plumber put the 'tee' fitting on the cold tap and now the dishie runs off the cold...I'm happy about that...it may sound picky but ever since that fitting was placed the water pressure has dropped quite significantly...I guess it's not that much of a problem...just takes a longer time to fill the sink...any ideas why the pressure dropped? Re: dishwasher plumbing dilemma 20Jun 01, 2010 4:25 pm Borg is probably right. Take the aerator off the end of the spout and clean it out. You probably got some muck through the lines when the plumber did his work and it has blocked the aerator/flow restrictor. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2852 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6341 I can totally relate to your shed project struggles—I recently tackled a similar ordeal, and it was quite the journey. Navigating through all those regulations and hoops… 4 8554 |
