Browse Forums Kitchen Corner Re: dishwasher plumbing dilemma 20Jun 01, 2010 4:25 pm Borg is probably right. Take the aerator off the end of the spout and clean it out. You probably got some muck through the lines when the plumber did his work and it has blocked the aerator/flow restrictor. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2905 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6396 Hi Sillysausage1900, Hope all is well. I came across this forum as Im somewhat same situation with you regarding Roof Plumbing certificate requirement. Im requesting a… 4 9668 |
