Browse Forums Lighting + Lighting Design Re: Favourite lighting 11Dec 11, 2007 5:14 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Favourite lighting 17Dec 11, 2007 3:14 pm Now make sure you let us know the date of that in advance won't you Steve????
We like to celebrate on Homeone!!!!! Re: Favourite lighting 19Dec 11, 2007 5:08 pm That's okay Steve, we'll celebrate on your behalf then.... Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29438 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9348 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9017 |
