Browse Forums Lighting + Lighting Design Re: Favourite lighting 11Dec 11, 2007 5:14 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Favourite lighting 14Dec 11, 2007 2:36 pm DeeElle wrote
Quote: Uber practical = pragmatic and reasonable Romantic soul = unpredictable and impulsive Takes both to create balance Sure does. So Here's a suggestion to everyone who's still reading this starting to stray from Creative Lighting Thread. Take it in turns each year to surprise your loved ones on your anniversary. Do it on a tight budget. That makes it all the more challenging and it helps to make you think ???? hmm how can I surprise and impress my loved one on that budget !!!! Anniversaries and birthdays are special things - so make them special for each other - and keep the spark alive. X-mas is the same. AND Now back to the lighting. Has anyone seen something they think would suit a high ceiling, 3.5 to 4 metres raked to roof exposed beams with LED or CFL. This is for a large room which is 5 metres by 6 metres with one window in it. Steve Re: Favourite lighting 15Dec 11, 2007 2:41 pm Yak_Chat That makes it all the more challenging and it helps to make you think ???? hmm how can I surprise and impress my loved one on that budget !!!! Anniversaries and birthdays are special things - so make them special for each other - and keep the spark alive. Steve Well arent you just the big softie then..... Now....when was that anniversary again....? Built Porter Davis "Dromana" 2007. Re: Favourite lighting 17Dec 11, 2007 3:14 pm Now make sure you let us know the date of that in advance won't you Steve????
We like to celebrate on Homeone!!!!! Re: Favourite lighting 19Dec 11, 2007 5:08 pm That's okay Steve, we'll celebrate on your behalf then.... Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29438 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9348 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9024 |
