Browse Forums Building Standards; Getting It Right! 1 Jul 09, 2025 8:54 pm I would like to remove windows to install French doors with a balustrade balconette, off of a second story room. What is the ledge width required protruding from wall? I don’t want a balcony as such that requires posts and beams underneath. The doors can open inwardly. Re: Does anyone know what the maximum width ledge is required for an external door with balcony 2Nov 21, 2025 4:09 pm Since your new French doors will open inwardly (which is critical), the protruding ledge—or "balconette platform"—is primarily for aesthetics, drainage, and structural finish.
If the doors were to open outwardly, the ledge would need to be much wider (e.g., 600mm to 900mm) and would require full structural support (posts and beams) to act as a usable balcony. I recommend consulting with a builder. Re: Does anyone know what the maximum width ledge is required for an external door with balcony 3Nov 23, 2025 6:53 pm AI responses such as these are typically unhelpful so do with it as you wish. Especially important to consider is those responses closing with “I recommend consulting with a builder” after giving such detailed, yet incorrect, information. A balcony such as you’ve described is called a Juliette balcony. There is no such code requirement that defines a minimum depth ledge. 1. A wider hallway always better, 1000mm is narrow if you are carrying things. Best find a hallway that you think is a good width and measure it. The problem is reduce… 1 21184 Performance solution. Im wanting to put a door within our shower so there is direct access from out pool outside to the shower. our bathroom us the same layout as the… 0 6729 Good morning, Thinking of using a PVC product for our balcony ceilings which are expected to have high exsposure to salt spray from the ocean. Has anyone here used PCV… 0 32874 |
