Browse Forums Building Standards; Getting It Right! 1 Dec 06, 2018 5:31 pm Hello Guys, I have a question about weep holes on a near completion house. I noticed in the pre-handover inspection that there is no weeping hole on the bricks under all the windows and doors. But I could see them on all of our neighbors who build with the same builder. Just wondering if this is something I should worry about for building standards and push our builder to fix before handover? Here are some pics at the front as an example but we got this issue all over our house, here is our house front: our houseLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is our neighbor: neighbourLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any help would be much appreciated. Re: Standards for weep holes under the window 2Dec 06, 2018 5:59 pm If masonry is weatherproof and window joints are properly sealed, weep holes are not required. In fact, what's the whole purpose of your bricks if they don't even protect from the water? Re: Standards for weep holes under the window 3Dec 06, 2018 6:32 pm Thanks for the reply. It seems that it could be ok to leave it. However, the only thing puzzle me is that we have 8 lots building with the same builder. All the other 7 got the window weeps holes and we are only one lot that does not have it. Re: Standards for weep holes under the window 4Dec 07, 2018 6:19 am Your window heads are in protected position under eaves and it is unlikely you will have a problem. From memory if a window or door is 1m or less it does not require a weep hole. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6242 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 12003 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10914 |
