Browse Forums General Discussion Re: Need advicesssss 3Oct 03, 2018 9:03 am IamSAM Need clarity on 28c - do you mean 2800cm that is 2.8m ? These days many builders offer 2.4m as standard. Some upgrade that to 2.6m. So in my opinion your 2.8m is quite good. The height of course is relative to other features of your house. I mean if you have a lavish design with super size tall windows, inclined ceilings and the works..then 2.8m may not fit in. If the CDC/Council approval is for 2.8m, then you will have to stick to that. Unless you redraft and resubmit the plans. Simply moving to another builder will not solve the issues instantly. Hi Sam Its 2.4meter that is extremely low, Need advicesssss 4Oct 03, 2018 12:58 pm 2.4m is standard, any higher would be extra cost I believe. Do you have a very tall family? So to get the extra ceiling height but at the same budget is unlikely. Because not only will the ceiling height change, but also the doors and windows probably. And wouldn’t you have to go through council again even if you change builders? I assume the height of you roof will change too. I’m not sure what 25c garage means. Re: Need advicesssss 5Oct 03, 2018 1:22 pm $189k for a 4x2 is pretty cheap especially if you are getting 2800mm ceilings. My suggestion is go and talk to the builder and ask them any questions you have. Going to another builder could take many months and $$$ if you have signed all the contracts Re: Need advicesssss 6Oct 03, 2018 1:29 pm 28 course is standard ceiling height, so unless you specified higher ceilings how is your builder ripping you off? Builder is correct in saying reworked plans will have to be resubmitted, depending on your house design it might be possible to increase some ceilings with bulkheads without resubmitting. But if you want to go higher you will be hit with extra cost & delays, switching builders a week before they go to site would most likely cost you more money & time. Re: Need advicesssss 7Oct 03, 2018 2:14 pm Sloppy $189k for a 4x2 is pretty cheap especially if you are getting 2800mm ceilings. My suggestion is go and talk to the builder and ask them any questions you have. Going to another builder could take many months and $$$ if you have signed all the contracts Hi there i am getting 28course which is 2.45m I believe, Re: Need advicesssss 8Oct 03, 2018 2:16 pm Hillsbuilds 2.4m is standard, any higher would be extra cost I believe. Do you have a very tall family? So to get the extra ceiling height but at the same budget is unlikely. Because not only will the ceiling height change, but also the doors and windows probably. And wouldn’t you have to go through council again even if you change builders? I assume the height of you roof will change too. I’m not sure what 25c garage means. Hi there As I said most all the builder will provide you 2.4meter ceiling height around the house and they ill give you 2.7meter in living area I guess, but my house has 2.4 meter all over the house which is not good right?! Re: Need advicesssss 9Oct 03, 2018 2:23 pm Huyyngg Hillsbuilds 2.4m is standard, any higher would be extra cost I believe. Do you have a very tall family? So to get the extra ceiling height but at the same budget is unlikely. Because not only will the ceiling height change, but also the doors and windows probably. And wouldn’t you have to go through council again even if you change builders? I assume the height of you roof will change too. I’m not sure what 25c garage means. Hi there As I said most all the builder will provide you 2.4meter ceiling height around the house and they ill give you 2.7meter in living area I guess, but my house has 2.4 meter all over the house which is not good right?! It’s not a given that living areas get higher ceilings. Usually extra, unless it’s a build with a higher base price to start off with. You wont need a permit to put in non loading partition but you will need a licensed plumber and a licensed electrician 1 6839 Ask yourself if the insurance company will be aware of the Reno. 4 8032 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6957 |
