Browse Forums Building Standards; Getting It Right! Re: House built 30cm to the right 42Apr 07, 2016 9:56 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: House built 30cm to the right 45Apr 08, 2016 3:13 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House built 30cm to the right 58May 14, 2016 6:06 pm Can't edit but was going to say 50mm not 30cm I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17862 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 6515 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10894 |
