Browse Forums Building Standards; Getting It Right! Re: House built 30cm to the right 42Apr 07, 2016 9:56 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: House built 30cm to the right 45Apr 08, 2016 3:13 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: House built 30cm to the right 51May 03, 2016 11:29 pm Hi, I have the same issue the builder has built the house 30cm to right of the set back. Could you share what was the outcome of the builder's meeting with the neighbours? Were you allowed also to attend? Also, is there a standard deviation tolerance that the council would allow as a reasonable error? Cheers, Gadi Re: House built 30cm to the right 52May 13, 2016 6:28 pm I wouldn't think 30mm will be an issue if your home is contained within your property Re: House built 30cm to the right 55May 14, 2016 12:47 pm Big stuff up. How they get the first floor wrong?? Ground floor must be out too Re: House built 30cm to the right 56May 14, 2016 12:57 pm There is 1.5m width on the ground floor between our set back and the neighbouring fence, however on the plans the 1st floor set back was supposed to be 1.8m but now it's only 1.5m. Is this within the tolerance deviation level, or will the builder have to demolish and rebuild? Re: House built 30cm to the right 57May 14, 2016 5:34 pm There is no tolerance. House must be built as per the plans unless you approve a variation. So the ground floor and first floor is 1500mm from the boundary in lieu of 1800?? What stage are u up too, was it pegged out wrong and are you happy for it to remain? Re: House built 30cm to the right 58May 14, 2016 6:06 pm Can't edit but was going to say 50mm not 30cm I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17862 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 6515 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10896 |
