Browse Forums Building Standards; Getting It Right! Re: My builder used the wrong bricks for a non-rendered wall 6Jan 30, 2016 3:11 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: My builder used the wrong bricks for a non-rendered wall 7Feb 15, 2016 5:37 pm Leksie5000 I'm not sure I buy the access issue - they needed access to lay them in the first place, right? I'd insist on the render. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Leksie5000 I'm not sure I buy the access issue - they needed access to lay them in the first place, right? I'd insist on the render. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 They will have been laid 'overhand' - that means from the inside of the wall not the outside. When the wrong bricks are used, usually the brickies demolish and rebuild. Not that uncommon. The brick work is not structural if in Victoria. Fast work to demolish and can be done very precisely these days with an arbourteck mortar saw. I would be expecting replacement. The wall shouldn't leak. All brick work absorbs water that is what the gap is for between the wall and the frame. Or if you agree to the metal strip don't just accept a credit for the difference, get a discount. there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18644 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 9254 Coming back to this.... When installing a pressure flashing, what fixings would you use (please give a link) ? Above Pedro said nylon anchors. Anyone have a preferred… 7 11838 |
