Browse Forums Building Standards; Getting It Right! Re: My builder used the wrong bricks for a non-rendered wall 3Jan 28, 2016 11:34 am AussieMark Could try removing the fence panels and have the builder render at his cost. The Shed and the other unit are a different problem. Hopefully a brickie or a building inspector can chip in with their thoughts. Thanks for your reply, Mark. The picture 1, 2 and 3 are the same wall from different angles; it's like 30cm away from the colorbond shed next door. The builder wants to fix a metal flashing from the wall to the shed so you won't see the gap and brick wall. I don't really know if that's a good idea Some advice from brickies or inspectors would definitely be very helpful Re: My builder used the wrong bricks for a non-rendered wall 4Jan 30, 2016 10:57 am I'm not sure I buy the access issue - they needed access to lay them in the first place, right? I'd insist on the render. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Re: My builder used the wrong bricks for a non-rendered wall 5Jan 30, 2016 2:29 pm Is there some way of removing the shed wall to provide better access. I would be worried about moisture. Re: My builder used the wrong bricks for a non-rendered wall 6Jan 30, 2016 3:11 pm Hi aaa93041 Well if you paid for Std creme Face brick (50 bricks per m2) then you should get a credit for the difference as you received 2 c brick (20 bricks per m2) without render Check your drawings and specifications with your council Building dept. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: My builder used the wrong bricks for a non-rendered wall 7Feb 15, 2016 5:37 pm Leksie5000 I'm not sure I buy the access issue - they needed access to lay them in the first place, right? I'd insist on the render. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 Leksie5000 I'm not sure I buy the access issue - they needed access to lay them in the first place, right? I'd insist on the render. Custom knockdown rebuild Newcastle NSW viewtopic.php?t=78271 They will have been laid 'overhand' - that means from the inside of the wall not the outside. When the wrong bricks are used, usually the brickies demolish and rebuild. Not that uncommon. The brick work is not structural if in Victoria. Fast work to demolish and can be done very precisely these days with an arbourteck mortar saw. I would be expecting replacement. The wall shouldn't leak. All brick work absorbs water that is what the gap is for between the wall and the frame. Or if you agree to the metal strip don't just accept a credit for the difference, get a discount. there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18542 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8765 Coming back to this.... When installing a pressure flashing, what fixings would you use (please give a link) ? Above Pedro said nylon anchors. Anyone have a preferred… 7 10662 |
