Browse Forums Building A New House Re: Henley Homes 2038Dec 04, 2015 9:49 pm hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. I believe it used to be mandatory to have the step down and then they changed it. It's only now required if your driveway slopes towards the garage. Regardless its still a good safety measure to have the step. In the event your garage floods it should prevent water entering the house. Cost was $450 from memory ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Henley Homes 2040Dec 05, 2015 10:19 am hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. I believe it used to be mandatory to have the step down and then they changed it. It's only now required if your driveway slopes towards the garage. Regardless its still a good safety measure to have the step. In the event your garage floods it should prevent water entering the house. Cost was $450 from memory Thank you, MichaelQ. Yeah I messaged my administrator to add that in. I haven't been to a house that has the same level of garage and house. Marina Henley progress: viewtopic.php?style=26&f=31&t=81630 At similar stage, seems like all builders these days try to make some hidden money from site costs. Will know more as it proceeds. Try out maximising your initial costs… 1 29517 check out the facebook page Building with Better Built - it helps! But i've heard both builders are fantastic. 1 160075 Yeah, that’s fair to be uneasy about it. We had similar wording pop up early on and our conveyancer pushed back hard. A few things were amended once we queried it,… 3 2640 |
