Browse Forums Building A New House Re: Henley Homes 2032Nov 30, 2015 10:24 am Yeah getting Darbecca to do inspection. Frame won't be completed until next week..just thought I point out to SS first before they put up the first floor particularly the excess concrete.. Thread: Emporer Nouveau Q3-Henley viewtopic.php?f=31&t=80918#p1473937 Re: Henley Homes 2034Nov 30, 2015 11:06 am Thanks Row, might point to him even though he warned us not to go into site.. What is the role of Ss? Aren't they suppose to check these stuff and advise contractors to fix? Re: Henley Homes 2035Nov 30, 2015 11:26 am We used to go on site all the time! I would then contact our SS asap with any issues and he would get them fixed or at least he knew about them in time. Just looked again at your pics. The knots Darbecca will pick up. We had a few and from memory they changed some, but others they got a letter from supplier saying they met the requirements. They were a bit reluctant to change these. Re: Henley Homes 2036Dec 01, 2015 12:47 pm Does anyone know where I can get that list to check off at different stages? I've heard you can buy it off home forum one for a few dollars. Re: Henley Homes 2037Dec 04, 2015 8:20 pm hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. Marina Henley progress: viewtopic.php?style=26&f=31&t=81630 Re: Henley Homes 2038Dec 04, 2015 9:49 pm hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. I believe it used to be mandatory to have the step down and then they changed it. It's only now required if your driveway slopes towards the garage. Regardless its still a good safety measure to have the step. In the event your garage floods it should prevent water entering the house. Cost was $450 from memory ------------------------------------------- Build Thread - Mainvue Emporio ER430 KDR https://forum.homeone.com.au/viewtopic.php?f=31&t=76790&p=1332227&hilit=mainvue#p1332227 Re: Henley Homes 2040Dec 05, 2015 10:19 am hi.. we are in the middle of tender and contract with Henley for construction. Was wondering if any had the same level as garage and house and if you had any issues with it? in the tender document it said that it is not required for step down garage. I believe it used to be mandatory to have the step down and then they changed it. It's only now required if your driveway slopes towards the garage. Regardless its still a good safety measure to have the step. In the event your garage floods it should prevent water entering the house. Cost was $450 from memory Thank you, MichaelQ. Yeah I messaged my administrator to add that in. I haven't been to a house that has the same level of garage and house. Marina Henley progress: viewtopic.php?style=26&f=31&t=81630 At similar stage, seems like all builders these days try to make some hidden money from site costs. Will know more as it proceeds. Try out maximising your initial costs… 1 29517 check out the facebook page Building with Better Built - it helps! But i've heard both builders are fantastic. 1 160075 Yeah, that’s fair to be uneasy about it. We had similar wording pop up early on and our conveyancer pushed back hard. A few things were amended once we queried it,… 3 2640 |
