Browse Forums Building Standards; Getting It Right! 1 Feb 03, 2014 6:31 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Is your build the minimum standard? 2Feb 11, 2014 10:03 am Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Is your build the minimum standard? 3Feb 11, 2014 3:56 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Is your build the minimum standard? 5Feb 12, 2014 4:23 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Is your build the minimum standard? 6Feb 12, 2014 4:30 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Is your build the minimum standard? 9Feb 12, 2014 9:50 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Is your build the minimum standard? 10Feb 13, 2014 4:39 am http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Is your build the minimum standard? 11Feb 13, 2014 6:18 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Is your build the minimum standard? 13Feb 13, 2014 8:17 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Is your build the minimum standard? 18Mar 25, 2014 11:59 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Is your build the minimum standard? 19Mar 26, 2014 6:02 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Is your build the minimum standard? 20Mar 27, 2014 8:14 pm Hi Again, The law you are referring to is hardly enforceable, and impossible to enforce in any court, as judge, expert witness or anyone else in building dispute case will not go to Builder's display house and compare workmanship, it wont be on. I have been expert witness in NSW Fair Trading against other builders and i have seen the law very well, i also work for Insurance companies and do all the repairs after builders go bust. Maybe other states have different process but in NSW that's just not on, expert witness MUST rely on Australian Standards, BCA clauses, Fair Trading guide of tolerances, Manufacturer instructions and so on, and not on some display house. No two tradies are the same, and they never will be. You can give same carpenter 2 doors to install next to each other, and doors will not be hung the same way, gaps wont be the same, lock will not fit and function the same way, height wont be the same, average people wont notice this but i will. No builder would write or state in his contract that your house will look exactly like the one on display, there is just so many loopholes on how he can get out of it. Once you come to CTTT or local Court same rules apply for builders with display homes and builders without them. I didn't like your post because many new families will read this and understand it wrong way, you basically said if your builder doesn't have a display house, don't build with him, well i have seen it all and i tell them don't EVER fall for their display home, and don't EVER think that you will get anything similar to that display home, regardless if its workmanship or inclusions, thats just my opinion. Im glad you come to these forums and help people, i wish i had more time to do the same. Please don't take it the wrong way Branko. My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 7351 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5947 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 16297 |
