Browse Forums Eco Living Re: Need advice on our rainwater collection and storage syst 43Oct 31, 2012 11:29 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need advice on our rainwater collection and storage syst 44Nov 01, 2012 4:48 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need advice on our rainwater collection and storage syst 47Nov 03, 2012 11:29 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need advice on our rainwater collection and storage syst 55Nov 22, 2012 9:31 am Hi John, It would be handy if you also have an Inspection Opening (I.O.) at each sediment trap. You have two choices here, you can either fit a separate fitting that would place the I.O. at either end of the 45 degree junction or you can buy an I.O. junction that has the I.O. directly above the bottom opening as per the image below. The bottom opening along the horizontal length won't be as large as the one in a 45 degree junction but the opening does slope downwards rather than have a direct fall and so it will capture most of the bed load provided the flow is laminar. The connecting elbow and taper at the bottom will be lower though. The fitting costs about $35 but that includes a cap and a removable fitting inside that seals the opening below the cap along the top horizontal section. I think that it is worth the investment. Regulations in some States also require two I.O.s. Your sediment trap drain should qualify as the second. Having the I.O. there will allow you to have a quick look inside whenever you drain the system and it will be easy to give it a quick clean if ever needed. You will need to box it with a top cover for access. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need advice on our rainwater collection and storage syst 56Nov 27, 2012 7:21 pm Agree, would be a smart idea for the long term. If I didn't have it I would always be curious as to what was going on in the trap. I had a look at the fittings at Reece. After adding a 90 degree bend on the bottom of the IO tee junction, the trap's 100mm pipe would run about 230mm below the top wet pipe. The trench would end up 500mm deep where the trap resides. I imagine I would then slowly bring the 40mm tail to the surface. I could run it in the same straight trench as the 50mm infeeds along to tank 4. It would then pop out the small bank at the end of the tanks with a valve to drain. The total 40mm run would be about 20mts. John Re: Need advice on our rainwater collection and storage syst 57Nov 28, 2012 12:27 am Hi John, Yeah, the bit of extra depth is a drawback but it will blast out at over 120 lpm with a 1 metre head over the pipe run you quote and so any slope is no big deal. The 20 metres will only hold 25 litres. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need advice on our rainwater collection and storage syst 58Dec 08, 2012 12:19 am Hi John, I thought that I would give you a recommendation at this stage about plumbing your pump to the cistern. Cistern valves are designed to cope with high pressure mains water but you will be reliant on tank water and a household pressure pump. I suggest that you fit the cistern with a 400UK063 Fluidmaster cistern valve, see below. They cost about $20. http://www.haron.com.au/fluidmaster_products.html This valve has two optional seals, a low pressure seal and a very low pressure gravity fed seal - the red one near the bottom of the page I have linked. They cost about $2.50. I have my cistern valve that draws from the pump fitted with the red gravity fed seal as I gravity feed to the cistern for probably 9 months of the year. When the pump is used (switched on), there are no problems with using the low pressure seal and I have been doing so for about 8 years now. Many people don't realise that water will flow through a pump when it is turned off and the flow path is open. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Need advice on our rainwater collection and storage syst 59Dec 10, 2012 4:34 pm Re above post and recommendation for the Fluidmaster cistern valve fitted with the optional gravity fed seal... John will not be able to gravity feed to the cistern as he will need his pump turned on at all times. My recommendation was to use the Fluidmaster cistern valve and the optional gravity fed seal as pumps operate with lower pressure than mains water supply as I posted. The valve & seal combination was suggested so that the pump would operate with less restriction and the cistern would fill faster. The reference to my cistern operating with both gravity feed and mains pressure was to indicate that the gravity fed seal wasn't restricted to operating only with gravity feed. I have since recommended to John that he consider fitting a header tank in the roof space to supply the cistern, something that should be easy to do as he is building. If this was sized to automatically fill at a pre set low level perhaps once a day, nearly 4,000 pump start ups would be eliminated every year. Re using a rear access junction to make a sediment trap, while this is a good idea, buying it from REECE PLUMBING is not!!!!!!!!!!! Check out the price for the same fitting from this online store. REECE PLUMBING charge about $35. It pays to Google first. http://www.pipeonline.com.au/listProduc ... S+JUNCTION 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19880 There is a whole lot more to know than just the answers you seek but they are a good start. Overflow outlets have a mosquito proof mesh. These… 3 8656 Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I… 7 31468 |
