Browse Forums Bathrooms and Laundry Re: Problems with shower niches?? 7Aug 13, 2008 7:09 pm We are building with PD and are having one niche in the kids shower with feature pebbles. We were told that there would be a "slight" slope to allow run off, we also have to seal our niche due to the pebbles so hopefully that might help with any leaks Happy at Home Re: Problems with shower niches?? 8Sep 28, 2008 7:51 pm We had a niche in our last house that we built. Just sold the house after 3.5 years.
No problems , and yes it did have a slight angle in it. We will definately be having one in the next house but it will be bigger.. This time it will be 2mtrs long! ( the length of our shower) Built a modified "Daydream 279" .. Cor@l Homes on a flat 4473m block!! And lov'n it!!! Re: Problems with shower niches?? 9Sep 28, 2008 9:54 pm We have them and they are fine!
No more build up than normal for grime etc and the water just runs out... Re: Problems with shower niches?? 10Sep 28, 2008 9:57 pm We have one in eacheshower with a pebble feature and have no problems. The water runs straight out. IMO they look a lot better than all the manky shower caddies I have tried in the past. Re: Problems with shower niches?? 11Sep 28, 2008 10:02 pm Re: Problems with shower niches?? 12Sep 29, 2008 5:22 pm This is a sore point for us also
After browsing many display homes, we had decided on a shelf-type niche running along the length of our showers (similar to that in VJ's home). Our builder however, informs us that the largest niche they can build is approx 45mm X 45mm! I am so disappointed as this is not what we are wanting and I think that this small 'box' will look out of place in our large double shower in the ensuite I just don't understand why we can't have what we want? Others have done it, why can't we? This question is on the top of the agenda for our pre-site meeting with the builder at the end of the week!!! Cheers, Dee ---------------------------------------------------------------------------- Our BLOG: http://buildingourdreams.blogspot.com/ Building the 'DEE 257.9' Contract signed 08/09/08. Re: Problems with shower niches?? 14Oct 03, 2008 1:51 pm How much extra are your builders charging you for these niches?
I said I wanted to put them in our bathrooms, but wife said no. Said it was an unnesessary expense. I agree, it's not necessary, but it sure does make the shower look nicer. Greg Re: Problems with shower niches?? 16Oct 03, 2008 2:27 pm If they are done properly like Matts are there should be no problem with leaking!
I truly think it depends on the builder, and if he can be bothered forming them up and mucking around with them as to wether you get them or not. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Problems with shower niches?? 18Oct 03, 2008 2:58 pm Greg, we paid about $300 for each of the two showers. They are both about 1.25m long as the little box size was not going to cut it. We have girls, can you tell?? Re: Problems with shower niches?? 19Oct 03, 2008 5:39 pm I noticed with Matt's bathroom that the bath hob had not been waterproofed in accordance with the Building Code of Australia. A lot of builders are missing this area - splash water on the area around the bath and water will penetrate through tot he supporting timbers.
I'll try and attach a diagram of how the waterproofing should be done - not sure how to do this. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 7123 Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 4001 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 3078 |
