Browse Forums Kitchen Corner Re: powerpoint on waterfall island bench 4May 27, 2009 5:00 pm Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: powerpoint on waterfall island bench 5May 28, 2009 12:36 pm If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 6May 28, 2009 2:04 pm Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: powerpoint on waterfall island bench 8May 28, 2009 5:12 pm If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 11May 29, 2009 11:59 am If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 13May 29, 2009 2:51 pm If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 16May 19, 2011 8:30 am __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: powerpoint on waterfall island bench 20May 19, 2011 4:25 pm I think that build was Nathan's? The only issue I would have with the pop-ups is that they will impact on whatever is below the benchtop. Ie in some cases you wouldn't be able to have a drawer as there may be a clearance issue. I have a double PP on the "dead" side of my island bench. It is the farthest away side so not seen unless you walk to that end. Both of my ends are 80mm waterfalls and as it was mounted on the side had no impact on the drawers / cupboards on the other side of the waterfalls. Some things are worth waiting for. Most builders will provide standard Island Bench with overhang. Can these standard island bench be modified to some of the ones shown in display houses? Or it is a case… 0 23360 You cant lay cabs on floating floors because they expand and contract. Direct stick floors are fine to do this. So floating floors after cabs with a bead around the… 1 24261 |
