Browse Forums Kitchen Corner Re: powerpoint on waterfall island bench 4May 27, 2009 5:00 pm Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: powerpoint on waterfall island bench 5May 28, 2009 12:36 pm If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 6May 28, 2009 2:04 pm Building our dream home - H3nley Ascot 384 Painting done - electrical, alarm and tiling being completed!! viewtopic.php?f=31&t=17939 Re: powerpoint on waterfall island bench 8May 28, 2009 5:12 pm If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 11May 29, 2009 11:59 am If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 13May 29, 2009 2:51 pm Quote: This is a snazzy idea So would that sit in the top of your bence and pop up for use Yeah, I'm guessing you'd just give it a light tap to make it spring up, then push it down into place when you're done. I've not seen it actually used anywhere, I just saw it in the catalogue and thought it was pretty cool. If we're put on this earth to help others, what are the others here for? Re: powerpoint on waterfall island bench 14May 18, 2011 11:54 pm We have a point on our waterfall side. Builder did it for us, conduit runs behind the cutlery drawers and through the next cupboard. It's my most used point in the kitchen, use it for everything http://i292.photobucket.com/albums/mm30/house-to-be/cremornestuff1793.jpg Hi i love this pic I was wanting to do waterfalls in stone on my l shape island bench, would you happen to have anymore photos of this bench thanks Re: powerpoint on waterfall island bench 16May 19, 2011 8:30 am We are going with the waterfall bench to only one side of the Kitchen (the side most seen be passers by and the other side I have a 30mm overhang with a power point on that side. My friend had her Kitchen built with 2 power points on the waterfall stone, it looked a bit odd to me and she had probs closing the drawers on that side. She is used to it now but I decided to go with the overhang. __________________________________________________________________________________________________________________ All new built homes look like display homes... until the furniture goes in. Re: powerpoint on waterfall island bench 18May 19, 2011 9:42 am We originally had a double powerpoint on each side of our waterfall bench and then ended up removing one of them. We removed the one that was visible to the rest of the house as the waterfall benchtop is a feature and we didn't want it ruining it (considering the benchtop is black). We have so many other powerpoints in the kitchen we figured how many electrical things will we have plugged in at once?? Why not just get black power points? (Hate the idea of not readily accessible power points.) Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: powerpoint on waterfall island bench 19May 19, 2011 3:44 pm How about a pop-up power point?? It would be less noticeable than a traditional outlet. Better still you can mount it on the top of your bench to avoid spoiling the look of your Caesaratone waterfall altogether. I saved the below photos from someone’s thread last year (sorry I can’t remember who and I hope they don’t mind)! They are made by Clipsal and are available in white too- I reckon if you have a white bench like ice snow or similar you would not even notice it if you place a fruit platter or something next to it. If the pop-ups don’t float your boat and you want an outlet on the waterfall itself then the Clipsal Saturns are pretty shmick too and come in slimline black and white- less obvious than a metal finish IMO. Cheers http://i1200.photobucket.com/albums/bb326/inverell/ClipsalPop-upoutlet1.jpg http://i1200.photobucket.com/albums/bb326/inverell/ClipsalPop-upoutlet2.jpg http://i1200.photobucket.com/albums/bb326/inverell/ClipsalPop-upOutletWhite.jpg Re: powerpoint on waterfall island bench 20May 19, 2011 4:25 pm I think that build was Nathan's? The only issue I would have with the pop-ups is that they will impact on whatever is below the benchtop. Ie in some cases you wouldn't be able to have a drawer as there may be a clearance issue. I have a double PP on the "dead" side of my island bench. It is the farthest away side so not seen unless you walk to that end. Both of my ends are 80mm waterfalls and as it was mounted on the side had no impact on the drawers / cupboards on the other side of the waterfalls. Some things are worth waiting for. Most builders will provide standard Island Bench with overhang. Can these standard island bench be modified to some of the ones shown in display houses? Or it is a case… 0 23360 You cant lay cabs on floating floors because they expand and contract. Direct stick floors are fine to do this. So floating floors after cabs with a bead around the… 1 24261 |
