Browse Forums Home Theatre & Automation Re: Data Cabling and You 103Apr 01, 2011 7:43 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Data Cabling and You 105Apr 04, 2011 11:09 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Data Cabling and You 107Apr 04, 2011 11:41 pm . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Data Cabling and You 108Apr 04, 2011 11:45 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Data Cabling and You 109Apr 04, 2011 11:57 pm Pugs the rules and regs that need to be adhered as in distances form other services and such....... Pepsi_Drinker .........If this perception is incorrect, maybe some of our data-cablers could explain the "technical" aspects of cable-tossing that untrained people either cannot do, or would not be able to do with a simple six-point checklist ? You're not helping your cause here Pugs !!! I don't have an issue with paying good money for good advice and technical expertise, but you're still not explaining why it's worth $100 / hour to run data cables in a simple domestic installation............. P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Data Cabling and You 110Apr 05, 2011 12:22 am Pepsi_Drinker You're not helping your cause here Pugs !!! I don't have an issue with paying good money for good advice and technical expertise, but you're still not explaining why it's worth $100 / hour to run data cables in a simple domestic installation............. P_D Please don't laugh at me more like 20- 30 point check list... Because I have Done a course and have a licence/ ticket to install cables and you don't.. I know all the Regs.. you don't ... I can sign off knowing the full install is completely Installed accoring to the Regs, even doing half the work and singing off on that part isn't good enough for the ACMA.., it isn't just for while one "person" lives in a house.. what about the next people they move see data points "assume" it was installed bya pro.. and then find out it wasn't due to issues with the runs of cable.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Data Cabling and You 111Apr 05, 2011 12:31 am Pugs .....Please don't laugh at me.... One of the issues with Internet forums is that it can be hard to gauge a persons actual meaning, hence my use of the "LOL" emoticon to convey my post was meant in good humour. It was not intended to cause offence, but as it obviously has please accept my apologies for the offence so caused. P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Data Cabling and You 112Apr 05, 2011 12:32 am too late.... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Data Cabling and You 113Apr 05, 2011 12:37 am Pugs too late.... Obviously I have caused offence, hence the proffered apology ................ P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Data Cabling and You 114Apr 05, 2011 10:49 am Not this old chestnut. The bottom line is that it is illegal to install data cabling without having had the appropriate training. It's exactly the same as installing electrical wiring without a ticket, or gas plumbing without a ticket. Sure, you could argue that they are potentially more risky for novices, but at the end of the day if you lay some cat6 over a pre-existing live electrical cable and cop a boot it's still gonna be nasty. Not to mention the potential for any errors one makes with the indisciminate running of cables to cause a fire hazard in the future. I don't understand why this is always source of arguments. You simply need to be licensed to run cabling. That's it. There's no middle ground. ...also I'd also say that referring to someone's chosen vocation as "dog's work" is a bit rough, even I take offence to that, and I'm not a data cabler. Cabling is skilled employment which at the very least takes good technique and skill to gain a desirable end product. I guarantee that I could tell the difference between an unskilled cabler and a skilled one, both visibly and through network performance. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Data Cabling and You 115Apr 05, 2011 11:38 am rockabilly_kid ..........I don't understand why this is always source of arguments. You simply need to be licensed to run cabling. That's it. There's no middle ground..... And that we all know and agree with, but you (and everyone else) must admit that there seems to be a fair bit of anguish about this topic, hence my post, trying to explain things from the "other side"....... Pepsi_Drinker I think a large part of the (perceived) problem is that....... I make no apologies for presenting MY OPINION on both sides of the argument ...... rockabilly_kid ........also I'd also say that referring to someone's chosen vocation as "dog's work" is a bit rough...... What I was trying to say, obviously with limited success, was that in many (most ??) professions there is the "skilled, technical work", and then there is the "mundane, everyday" work that is frequently done by others. As a few examples, brickies have labourers to mix their mortar and cart their bricks, and I think no less of brickies labourers then I do of brickies, I recognise that they are different jobs, each worthy of respect. We give our garbos and posties a six-pack of Coopers Pale Ale each Christmas, and have done so for as long as I can remember, again worthy jobs deserving of respect. More examples ?? When was the last time a dentist cleaned your teeth ? For the last 10 or more years he has got the "Dental hygienist" to do that for you. Got an injection from your local doctor lately, or did they get their nurse to do it for them ? Many (most) large mechanical workshops have TA's to assist their mechanics, and I hope that you'd think no less of the TA's then you do of the mechanics ? My point is though, if the hygienist cleans your teeth you don't expect to be charged the same rate as if the dentist cleans your teeth, you expect the doctors surgery to charge you less for seeing the nurse then the doctor, at the pathology centres the RN takes your blood sample not the doctor who will analyse it, and if the TA paints your tyres (showing my age now) you don't expect to be charged full mechanics rates ............ And getting back to topic, I hope that this explains a bit where I'm coming from ? So, again, sorry if I offended by my (poor choice of) words, but hopefully this can help to explain the "view from the other side" ? rockabilly_kid ..... even I take offence to that, and I'm not a data cabler...... I am sorry for the offence I caused him (and any others), we had communicated via e-mail a couple of times regarding data-cabling for my new house, so while I don't know him personally, I have no reason to doubt his skill, abilities or professionalism, but I do hope that we can all agree that it would be a sad world if others cannot put their thoughts forward when they disagree with someone else. P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Data Cabling and You 116Apr 05, 2011 11:43 am Pepsi_Drinker ......One of the issues with Internet forums is that it can be hard to gauge a persons actual meaning, hence my use of the "LOL" emoticon to convey my post was meant in good humour. It was not intended to cause offence, but as it obviously has please accept my apologies for the offence so caused. P_D What I said yesterday !!!! P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Data Cabling and You 117Apr 05, 2011 12:04 pm I understand where you're coming from, but the literary sledgehammer you used possibly wasn't the tool for the job. I also got carried away and missed you major point which was why have a pro come and charge labour on top of what would otherwise be a cheap (and in your eyes, easy) job. I was going to just mention plumbing as an example where you get charged an extortionate amount to have a hairy-knuckled monkey come out and put a new u-bend under your sink which requires little skill short of cutting PVC and using a swab of plummers glue. (If you're a plummer by trade, this will be a most ironic post!). Cablers by comparison charge peanuts for labour, and they're not even the monkeys! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Data Cabling and You 118Apr 05, 2011 12:23 pm Get a wireless connection to the outside world and do all your own data cabling. Just make it impossible to electrically connect to the outside world and, unless I see specific legislation otherwise, I don't see any problem with this. Remember, specific legislation that says I can't do this - no airy-fairy stuff or I know. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Data Cabling and You 119Apr 05, 2011 12:47 pm Quote: The bottom line is that it is illegal to install data cabling without having had the appropriate training. I guess I'm breaking the law for plugging my 1 meter CAT6 from my PC onto my Router (TPG's IPTV doesn't work very well on wireless). Does anyone know if I'm breaking the law by plugging my 1 meter toaster chord onto the wall socket? I don't have an electrical certification. Re: Data Cabling and You 120Apr 05, 2011 1:06 pm Hilarious. We're talking about fixed data cabling in walls and roof spaces though. If you made you patch lead yourself though, there may be some issue. But of that i'm not sure. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 21224 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 14109 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 11545 |
