Browse Forums Lighting + Lighting Design Re: Lighting Options - Told Halogen downlights not available 12Feb 17, 2011 12:04 pm You can use halogens. But if you are going to use them, consider the IRC halogen - 35W for the saem light output as a 50W. With regard to CFL, I used 13W CFLs throughout the house on the same spacing as halogens and it looks fine. And if you think it's too dul there are 15W and 18W CFLs that can be swapped in. In all cases I'm talking about 240V bulbs with a GU10 fitting. The beauty here is that you can readily move between halogen (IRC or not), CFL and LEDs. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Lighting Options - Told Halogen downlights not available 13Feb 17, 2011 1:38 pm ![]() ![]() We also installed Brightgreen's led downlights last year but our electrician got them for $115 each. We are very happy with them and receive lots of comments from our visitors. Do you have a few pics sue? I`m considering installing them in the near future but i`m unsure of how effective they are in regards to brightness and light spread. Thanks Phill Re: Lighting Options - Told Halogen downlights not available 14Feb 17, 2011 1:45 pm Hi Donna We installed 48 of the D900 lights. Phil I'm sorry I don't have any pictures but I noticed Brightgreen has started a facebook page with a few photos on there. The brights are very bright and I believe you can pick between a 45 and 55 degree beam width. Hope that helps Sue. Re: Lighting Options - Told Halogen downlights not available 15Mar 26, 2011 11:54 pm Hi Sue (and others)...... Just checked BG's FB page, no real pictures of the lights actually "working". Any chance of a couple of snaps of them in action ? Thanks, P_D . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: Lighting Options - Told Halogen downlights not available 16Mar 29, 2011 9:14 am If anyone is in Melbourne (Bundoora) I have a dark room that I am happy to show the D900 in the roof. Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 29482 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9399 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 9093 ![]() |
