Browse Forums Building A New House Re: Have I missed anything? 5Mar 02, 2008 7:55 am Forgot to mention a few things!
Your island bench should already have microwave provision unless it has 2 pot drawers on top of one another. We went ahead and ordered the Technika stainless microwave and trim kit so it all looks integrated in the bench. If you can, have a look at the Montego display at Berwick to see what I mean. R4.0 insulation is fine, and a lot thicker than what some builders use. One builder we sussed out only used R2.5 in the ceiling but his house still complied with 5 star energy rating, so I can only assume that with R4.0, double glazed windows, solar hot water and correct orientation, M comply easily. We're getting 2550m ceiling height as part of the M Style package and sticking to standard size doors; all the display houses are like that and they look fine. Think of Grandma's old house on the farm with 10 ft ceilings and standard doors, it doesn't look out of place at all. Extra batten holders only cost about $40 or so but they don't give you bulbs with any of them! We've upgraded to 4 star heating mainly because basic 3 star units can be noisy. 5 star should be even better I guess. We have also organised to get a separate circuit 'pre-wired' in preparation to getting a split system air con installed after handover. With eaves, tinted windows, lots of tiles, high ceilings and the split system we reckon we've got our cooling licked. DO NOT get evaporative cooling. They are primarily designed to work in inland areas where there is little humidity. In coastal areas they are no better than a ducted fan. Re: Have I missed anything? 6Mar 02, 2008 8:25 am Thanks everyone - I knew I would get more ideas from here
Ray - I am most likely building the Laguna - it has a WIP which is fine by me, so do you mean I will have to pay extra for a door for the WIP? If so I will definatly have to do that my pantry is a mess at the best of times Toilets is a good one - One I didn't even think of!! They had mirrored robes in the display home but with my two kidlets I can't imagine wiping them all day I'd be happy with standard there I get the tiled showr bases/remote control for garage as part of the promo pack but I may have to add another remote for my husband....Good point!! With the brick infills above windows I know what you mean, I've just had a read of M's Standard Inclusion list and it states 'Double story home - All elevations except single story selection - Brick infills over all windows. Single story selection - side or rear. Fibre cement sheet infills. Does this mean if I am building a double I will get brick infills above all windows or does it mean I will still have to pay extra for brick infills above ground floor windows...if so another upgrade I didn't think of, so thank-you!! Oz now - Privacy locks is a good one!!! I didn't even think of it. Downlights I am stuck on, I really don't like the look of heaps of little ones lighting up a room, in the display home they had like 8 downlights for the TV area I would have prefred 1-2 bigger ones but not sure if it is an option? Eager - Wow thanks heaps! You have given me heaps of extras to enquire about. I like your thinking for the kid's wardrobe fitout - very clever!! What is a portico ? Also eaves? I think I have an idea about eaves but would like to see a pic of a house with them and a house without them....Alot of the upgrades - window locks/flyscreens/upgrade cooker etc are alot cheaper than I thought, got to be a good thing right Thanks again - and keep them coming!! I have 2 pages so far!! Cheers Belinda Re: Have I missed anything? 7Mar 02, 2008 9:04 am The portico is the "arch" or pillars at the front of the house that you walk through just before you get to the front door. The eaves are the overhang from the roof that provide shade for windows/paths etc...
It's so good to see people using this website BEFORE they have a contract. If only we all had that much information before signing our contract Re: Have I missed anything? 8Mar 02, 2008 9:11 am We used Adlei glass for our glass splashback and found them to be a lot cheaper than others, we found them via their website www.adleiglass.com.au hope i can save you some coin. Re: Have I missed anything? 9Mar 02, 2008 9:16 am haywgl, theres always going to be upgrades that you will see when you go in to chat to them...Paint quality, more expensive tiles for the wet areas, more expensive caeserstone door handles, taps....all can be upgrades if you want?
There is also things like sound-proofing which is often overlooked? We soundproofed the theatre, the walls between the kids rooms & the entertaining areas, the bathrooms etc.... might be something else you might want to consider. An external gas point for an outside bbq if you want to? A ceiling fan for the alfresco area??? Heat lamps/fans in the bathrooms instead of the plain exhaust fans. Security system? Ask them for a list and you should have plenty of options available to you??? Good Luck!!! Re: Have I missed anything? 10Mar 02, 2008 9:58 am haywgl Ray - I am most likely building the Laguna - it has a WIP which is fine by me, so do you mean I will have to pay extra for a door for the WIP? If so I will definatly have to do that my pantry is a mess at the best of times Toilets is a good one - One I didn't even think of!! They had mirrored robes in the display home but with my two kidlets I can't imagine wiping them all day I'd be happy with standard there I get the tiled showr bases/remote control for garage as part of the promo pack but I may have to add another remote for my husband....Good point!! With the brick infills above windows I know what you mean, I've just had a read of M's Standard Inclusion list and it states 'Double story home - All elevations except single story selection - Brick infills over all windows. Single story selection - side or rear. Fibre cement sheet infills. Does this mean if I am building a double I will get brick infills above all windows or does it mean I will still have to pay extra for brick infills above ground floor windows...if so another upgrade I didn't think of, so thank-you!! Belinda, You can turn a WIP into a "butlers pantry" by adding a kitchen bench with cupboards above and below - but this is an extra. You should have the door on it already, but we didn't find out until our walk-through that the bench in the display was extra. As your design is double storey, you should have brick infills already - the only thing to check would be that the windows on the top floor have them too, as the bottom floor ones have to have brick above them, as this becomes the wall of the top storey (hope that makes sense). Robes - you can opt for sliding vinyl or solid doors (hinged) at no cost, so unless you want mirrored, they should be standard. As far as robe fit outs, the lady that did our walk through said that they are quite expensive to do through M and in her opinion not worth it - it would be better to get it done afterwards. We didn't upgrade this, but probably wouldn't hurt getting a price for it. The shelf with a hanging rail underneath comes as standard. Shower base - like you we had one included in our promo package but upgraded the other one too. Also, your portico will likely be determined by the facade you choose (what it looks like from the street), but render is usually extra. As far as the doors go, we have some 2040 (standard height) and some 2340 (higher) with the 2550 ceilings. IMO the 2340 look better and make the roof look higher. We have the higher in the entry/master/kitchen with the standard for the back passage/bedroom and pantry doors. It was $66 per standard door to upgrade to the higher ones, and in hindsight probably should have done that throughout but the line has to be drawn somewhere otherwise we would have EVERY upgrade! We also have 2 sikkens (Corinthian Windsor 21) doors (they are the ones they normally have on the displays - wood surround with glass centre) and depending on the size can be about $1000 ea, but they are a feature. You will also probably find that the higher ceilings are for the ground storey only - I don't think any builders provide higher ceilings upstairs. Going through our contract, extras were: 1) Temporary site fencing - most councils require this. 2) If your garage is right ont the boundary you require "boundary flashing" to conceil the gutter so it doesn't poke onto the neighbouring land and you don't end up with a minute gap between the houses. 3) Extra cavity sliding doors on places like the ensuite and back passage (may not be applicable) 4) Upgrade the standard sidelights to match the upgraded front door (I didn't like the standard glazing) 5) Shelf/wine rack above the refrigerator space 6) One cupboard converted into a full sized drawer to accomodate the bin 7) Drawers in the ensuite/bathroom as usually only the doors and possibly and open shelf are included Semi-frameless shower screens (personal preference - again, chosen at 501) 9) Tiling/floorboards to floor areas apart from "wet areas" (if you decide to go with them) 10) Dimmer switches if you require them 11) Telstra connection including the trench Oh, and we were told that M don't do refrigerated cooling - only evap. If you do get the evap cooling you can opt to get the heating and cooling both wired to the same controller for a small extra cost (saves having 2 panels on the wall). The list is endless and will depend on your design and personal tastes. All I can say is include EVERYTHING you can think of, then you can do various calculations and decide what stays and what goes. Ray. Second Time 'Round Re: Have I missed anything? 11Mar 02, 2008 10:15 am Eager - Forgot to add we will be getting refridgerated air con - it is my husbands one and only wish for the house
Southbris - thanks for that info - I now understand why Eager would render the portico - would look good, will definatly add that to my list!! I agree before i found homeone I had no idea the house building game was so full - on, this site has saved us so much money and provided us with so much useful information - it is unreal! MelC- thanks for that will definatly check them out!! Phoneix - I agree - it is more about missing the things you can't see that I am worried about - I also think these are the type of things you can't 'fix'as easily after handover. The soundproofing is a good idea, we have a portable BBQ so shouldn't need the gas outlet, the fan in the alfresco is a good idea I was thinking of just asking them the price for the bathroom and kitchen I saw 'as displayed' and then remove the extras/change the colours of what I didn't want.... Ray - You have brought up some great points! I do get what you mean about the brick infills, we are probably going for the contemporary facade - which is an extra - I remember the one at Pt.Cook was painted - so we would probably have that upgrade! Damn - I would have thought M would do refridgerated cooling, hmm that has thrown a spanner in the works - I hope they will let the guys on site to do it if thats the case as I am assuming it would be much easier to do it b4 handover... The 2550 ceilings are only for the ground floor so we will also opt to upgrade the second story - probably a few thousand more I would assume... Gosh there is so much to think about!! Thanks again! Re: Have I missed anything? 12Mar 02, 2008 10:33 pm Hi Belinda,
I missed this topic! Anyway, lots of people have already contributed and almost everything were already mentioned. Why not book a walkthru at 501 so you get an idea what are the options available to you during your colour selection (you can do this online). In addition to what they mentioned, you may want to upgrade: - acoustic insulation (if you want a HT area) - upgraded internal doors (solid, instead of cori-tech internal doors) - sliding doors (pantry, laundry, etc) - around $300+ to add cavity sliders - window to the kitchen (to give natural light) - the privacy locks to the powder, toilets, etc will only cost you $35-$40 each and yes, having eaves depend on your chosen facade. ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! Re: Have I missed anything? 13Mar 03, 2008 7:53 am VJ and yes, having eaves depend on your chosen facade. Well, er, yes, no, maybe, depends! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is a representation of our facade, with a prominent portico. We are also getting eaves, so the solution is to extend the portico towards the street by the same amount as the width of the eaves, 600mm overall. This keeps the portico standing proud of the house by the same amount as if eaves are not there. Re: Have I missed anything? 14Mar 03, 2008 8:03 am Thanks VJ - Will definatly book a walk through of 501 - I got some great ideas of colours from the display home - I know I want an all white kitchen and the bathroom in the Laguna was perfect so I'll have to find out the names of the colours and then check them out at 501 - I'm sure they are upgrades
Oh while I'm at it I'll ask you V - Did M give you an option of refridgerated a/c, or did they tell you the same as Ray - that it wasn't an option? Also did you keep the standard R 4.0 Ceiling and R 2.0 insulation for Walls or did you upgrade? (Excluding home theatre) The solid doors and sliding pantry/laundry is a good one!!! Hmm I'll have to see about the eaves etc, i can't remember if the one at pt. cook had them or not Thanks again guys - I have a list of 35+ extras to get quotes for! Re: Have I missed anything? 15Mar 03, 2008 5:29 pm Belinda,
If you want the same colours/finishes as that of Laguna (Pt Cook), you just have to ask your colour consultant during your colour selection appointment. When you go to Studio 501 for a tour, the people there don't have a list of the colours used in different display centres. You will be able to get those colours, as I've said, during your colour selection appointment. We weren't interested with refrigerated a/c that is why we didn't ask. Re: the insulation, we didn't upgrade. Quote: The solid doors and sliding pantry/laundry is a good one!!! Definitely, saves space! Re: the eveas, I checked your facade, it doesn't have the eaves yet. So, you need to upgrade if you want one, and it might not look good on that facade. The Modern facade is a nice one and it's got eaves already! ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! Re: Have I missed anything? 16Mar 03, 2008 6:41 pm VJ - We must have very similiar tastes as the modern facade is actually my favourite one!! I'll get a quote tomorrow -(yup I have my appointment finally!!)
I will definatly ask about the bathroom colours in the Laguna display home - one less job to have to decide on too! That's good I don't have to worry about upgrading insulation either - I am saving more money as I go!! There is a new current promo offering 1 of 2 options for free, you can choose from one which includes driveway, paths, tiles to ground floor, carpet to the remainder and flyscreens to all openable windows OR one that includes higher ceilnigs, downlgihts, pivo front door, caesersone benches to kitchen, o'head cupboards, stainless dishwasher, tiled shower base and laundry fitout (very similar to the indulgence promo they have for $5000 but a few changes) so I think I may pay he $5000 for the indulgence ack and choose the first option so I can get the driveway etc for free, however, I will just tell them to exclude the tiles (as I want timber) and instead upgrade the carpet....hopefully they will agree I'll find out about the refridgerated a/c tomorrow too! Very excited - will let you all know how we go! Cheers Belinda Re: Have I missed anything? 17Mar 03, 2008 6:58 pm Quote: There is a new current promo offering 1 of 2 options for free, you can choose from one which includes driveway, paths, tiles to ground floor, carpet to the remainder and flyscreens to all openable windows OR one that includes higher ceilnigs, downlgihts, pivo front door, caesersone benches to kitchen, o'head cupboards, stainless dishwasher, tiled shower base and laundry fitout (very similar to the indulgence promo they have for $5000 but a few changes) so I think I may pay he $5000 for the indulgence ack and choose the first option so I can get the driveway etc for free, however, I will just tell them to exclude the tiles (as I want timber) and instead upgrade the carpet....hopefully they will agree If you decide to change any items in the promo, it will be costing you more. You would get a small credit for item replaced (eg. tiles) and an expensive cost for the replacement (e.g timber flooring). That is, if they agree. I reckon the carpets and tiles are all category 1. Compute first whether you would save more by choosing option 1. I have the quote for category 1 floor tiles/carpets (but it's for the signature houses). ----------------------------------------------------------------------------------------- Built the Nevada 42 Next project - landscaping! Re: Have I missed anything? 18Mar 03, 2008 7:36 pm Hmm I see your point V - your right, I was originally just going to pay the $5000 for the indulgence pack and then they told me about choosing one of these options for 'free' and it sounded to good to be true
I'll just get all the quotes tomorrow and work from there... I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 37391 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 41596 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 24655 |
