Browse Forums General Discussion Re: What happens with small permanent errors? 5Jan 26, 2010 9:09 am Where you are coming from is where you are going to... Re: What happens with small permanent errors? 6Jan 26, 2010 7:05 pm The plumber seemed to not allow for tiling and other space considerations when putting in the plumbing ... which meant the rings were removed (so ... the laundry seems OK, the shower not OK). I assumed that they had to move the entire T part forward ... will check again. Another small thing ... new door was supposed to be made to match the existing front door ... it is close ... very close ... but a slightly different cricket bat kind of finish (old door is probably 100 years old so hard to match) ... it is all painted up and done ... re-doing it for a fairly minor finish seems a bit ridiculous (doors are no where near each other, I'll probably be the only one who ever notices ... and can't say it seems worth making the builder totally re-do the door ... but it does annoy me a little bit!) Re: What happens with small permanent errors? 7Jan 29, 2010 1:26 pm Personally I feel if you specify something and want it how you said and paid for it it should be 100% and if your not happy they fix it or you dont pay. It seems to only ever work one way and thats in the builders favor where you have to compromise and they get away with stuff. We are not allowed to change anything or not pay in full so they should do their bit 100% also!! The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5866 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 7042 Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 5211 |
