Browse Forums Home Theatre & Automation 1 Sep 26, 2009 9:29 am We have just put on an extension, the room is 7m wide, 5m deep. We have a 2m wide niche for the tv. I am just wondering what would be the best size TV. My husband wants a 58inch bt I am worried this is a bit of overkill. Any ideas would be great, he wants to buy it today! Here is the room Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Best size TV for this room? 2Sep 26, 2009 9:49 am It depends on how far back you sit from it. If you sit over 4m back then 58" will not be too big, but if you are closer than 4m then some may feel it is too big (I just upgraded to a 50" from a 42" as my new rumpus has me sitting 4-4.5m back and it looks good, but I don't know if I'd want a 58" in it's place...). It is a taste thing too... Re: Best size TV for this room? 3Sep 28, 2009 9:49 am If the aesthetics of a large TV in the room are a worry for you then maybe think twice about a 58" model because it'll be a big of glass in the room. If however that isn't a concern (and it shouldn't be! ) then you will be surprised at how quickly you will get used to the size. For the first week or two it'll seem huge but you will rapidly adjust. The only issue will be that at 58" any deficiencies in the picture, either from limitations in the source material or lack of ability of the TV itself, will become glaringly obvious. So make sure that in the shop you like the picture and aren't just dazzled by the size (and the overblown oversaturated cartoon-ish colours that the shopfloor model will undoubtably be set to). All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3904 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3980 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 6541 |
