Browse Forums DIY, Home Maintenance & Repair Re: Oil staining on concrete.... 10Sep 17, 2009 10:44 pm joelwinson25 The simplest and the best way to remove those oil stains on the floor of your garage is to use OIL GONE EASY HOME & DRIVEWAY S-200. The product works on any surface, be it concrete or cement. If you want to know more about it, you can check out their site at http://oilgoneeasy.com Would you buy something endorsed by a guy called "Mr Fix It Lou Manfredini" ? Re: Oil staining on concrete.... 11Sep 17, 2009 11:33 pm My dad is a motor mechanic and uses petrol to clean up fresh oil Hi, I have an area of zincalume cladding encasing a number of external downpipes. Unfortunately one of them has been permanently stained by some diluted phosphoric acid -… 0 1034 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2717 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13522 |
