Browse Forums DIY, Home Maintenance & Repair Re: Oil staining on concrete.... 7Jul 08, 2009 4:39 pm Hi guys, Just to put my previous post into perspective, there are oil stains...and there are oil stains. I agree that the above degreasers will work very well and it is good to hear of real experience with them especially those cheap ones, but they only work on the surface. Give it a day or so and if the stain was old it will return again. Sure, no oil on the surface however the dark stain will come back up again so my post was a cheap way to get most of it up from below the surface. Also the laundry detergent was a cheap option because the lady of the house usually buys that, but do not get caught! If you spill oil onto the concrete any type of strong detergent or degreaser will work well, but if the oil has been soaking in the hot sun for ages then it will have stained deeper down. In factories under machines that have leaked oil for decades the oil goes all the way through and into the soil. Oil stains are a real pain on concrete and not much gets it out that I have seen, you can only make it better. I used to epoxy paint factory floors, mainly old engineering plants with totally oil soaked floors. I pressure cleaned off the surface muck with my water jet floor mower and recycled the water. After 6,000 psi there was nothing left on the surface, but it was still an oil soaked floor. Then I would flood the floor with a strong detergent and use a ride-on scrubber to agitate it and vacuum pick it up. After two rinses and vacuum pick up we would paint as soon as it dried which took about an hour and it was guaranteed not to peel for life. Tests I did years ago suggested that this system removed everything from perhaps the top 0.5mm only. That was enough for the paint to adhere strongly. If we waited too long it took only 2-3 hrs in summer for the worst stains to appear at the surface again and we would have to spot clean those just before painting. Sorry to bore you, thought it might be interesting to some. Re: Oil staining on concrete.... 9Sep 17, 2009 10:24 pm The simplest and the best way to remove those oil stains on the floor of your garage is to use OIL GONE EASY HOME & DRIVEWAY S-200. The product works on any surface, be it concrete or cement. If you want to know more about it, you can check out their site at http://oilgoneeasy.com Re: Oil staining on concrete.... 10Sep 17, 2009 10:44 pm joelwinson25 The simplest and the best way to remove those oil stains on the floor of your garage is to use OIL GONE EASY HOME & DRIVEWAY S-200. The product works on any surface, be it concrete or cement. If you want to know more about it, you can check out their site at http://oilgoneeasy.com Would you buy something endorsed by a guy called "Mr Fix It Lou Manfredini" ? Re: Oil staining on concrete.... 11Sep 17, 2009 11:33 pm My dad is a motor mechanic and uses petrol to clean up fresh oil Hi, I have an area of zincalume cladding encasing a number of external downpipes. Unfortunately one of them has been permanently stained by some diluted phosphoric acid -… 0 1007 I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying? 0 2626 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13190 |
