Browse Forums Bathrooms and Laundry Re: All I want is constant temperature while having a shower!!! 4Apr 25, 2009 6:54 pm This is a pet hate of mine!! I don't know why we all build houses with several showers when we can't use more than one at the time for this very reason.
We had the same issue in our old house even though we had Rinnai Infinity instantaneous gas system with temperature controller (which by the way does not keep the water at constant temperature, just sets the maximum temperature) - and we still have the problem in our new house with solar HW plus gas booster (we were told we couldn't have the temperature controller with solar HWS). Edit: Just checked Rinnai website and their claim is that their temperature controllers maintain water temperature when other taps are open but this certainly wasn't true when we had one (about 3 years ago) - they might have improved the thing. Re: All I want is constant temperature while having a shower!!! 5Apr 25, 2009 6:57 pm Where we currently rent there is a aquamax instantaneous hot water system. No-one is allowed to flush the toilet when anyone is in the shower as the result is instantaneous!!! Fi has moved in!! Re: All I want is constant temperature while having a shower!!! 6Apr 25, 2009 7:05 pm brittany Where we currently rent there is a aquamax instantaneous hot water system. No-one is allowed to flush the toilet when anyone is in the shower as the result is instantaneous!!! Ahhh, same as with our place Absolutelly hate it! Re: All I want is constant temperature while having a shower!!! 7Apr 25, 2009 7:09 pm I believe that the rating (litres per min) of the instantaneous gas hot water system also plays a part (eg both showers been used at the same time). Thus, I upgraded to 26L/min. Chris Re: All I want is constant temperature while having a shower!!! 8Apr 25, 2009 7:10 pm if you turn off the electrics or gas the water will remain at a constant temperature ’’Quondo Omni Flunkus Mortati ’’ If the women don't find you handsome, they should at least find you handy. Stila BK1 Build Thread The best place to talk about sport Re: All I want is constant temperature while having a shower!!! 9Apr 25, 2009 7:12 pm serge44 if you turn off the electrics or gas the water will remain at a constant temperature ha ha! very funny Re: All I want is constant temperature while having a shower!!! 10Apr 25, 2009 7:29 pm Our rental is exactly the same. It's very annoying especially when you tell the kids not to flush while your in the shower and they still do. Sorry Mum it was an accident. Yeah right that's punishment for yelling at them. Re: All I want is constant temperature while having a shower!!! 12Apr 28, 2009 1:58 am We had the same thing where we are living here in Canada. We are in a basement suite and when the landlords living upstairs used their water our shower would go freezing or very hot (actually once did burn my wife a little bit) The landlord swapped our faucet in the shower around to a mixer type one that through some fancy plumbing (no electrics?) keeps the pressure up if it detects a fall - is guaranteed to never vary by more than a degree. We've had no problems since then! I know over here you can also get manifold type systems for your plumbing (similar to an electrical switchboard) that do a similar pressure thing but with all the taps from a central location. Here's a couple of examples of what I mean: http://www.houseneeds.com/shop/plumbing/pexplumbing/vanguard/pexmanifoldsbuypage.htm http://www.hgtvpro.com/hpro/bp_mechanical/article/0,,HPRO_20151_4538091,00.html Not sure what's available in Australia in this regard but when we build when we get back will definitely be getting the builder to make sure that we will not have this problem! After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: All I want is constant temperature while having a shower!!! 13Apr 28, 2009 4:52 am you should change all the old instalation Re: All I want is constant temperature while having a shower!!! 14Apr 28, 2009 7:43 am muzzman The landlord swapped our faucet in the shower around to a mixer type one that through some fancy plumbing (no electrics?) keeps the pressure up if it detects a fall - is guaranteed to never vary by more than a degree. We've had no problems since then! You'd better come back, you're going native...faucet indeed! mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: All I want is constant temperature while having a shower!!! 15Apr 30, 2009 3:50 am to_do_list muzzman The landlord swapped our faucet in the shower around to a mixer type one that through some fancy plumbing (no electrics?) keeps the pressure up if it detects a fall - is guaranteed to never vary by more than a degree. We've had no problems since then! You'd better come back, you're going native...faucet indeed! Oh... oh.... um.... oh dear.... ... aussie thoughts aussie thoughts... ...meat pies, potato cakes, dim sims, tim tams, vegemite, AFL, Shane Warne, warm weather, beaches, Uluru.... aaaaaaaahhhhhhhhhhhhhhhhhhh *sigh of relief* They're called taps!! Shane Warne? How'd he get in there? After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: All I want is constant temperature while having a shower!!! 16Apr 30, 2009 10:05 am Easy solution to the loo flushing problem in our (rented) place - we reduced the flow rate into the cistern until the temperature in the shower was fairly constant. I just wonder if buildings still have taps for each cistern? The slight drawback is if you need to flush twice, you have to wait longer. We also have asked for the faster flow rate water heater in our new house, hoping this will reduce the problem of two showers not being able to be used at the same time somewhat. Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Hello everyone Please advice me how can I install mesh security window or we cab say mesh flyscreen inside while the pvc plantation shutters are already installed? Is… 0 12371 Sounds like rubbish to me. Ask for the contamination report which I doubt they have. If it's part of a normal subdivision it would have had a contamination report done… 9 5981 |
