We are thinking of getting two air/con units. One for each floor. I know it will cost more initially but it would save money in the long run, right? What do you guys think? Is it worth having two or would you just get the one?
Browse Forums Heating, Cooling & Insulation Re: 2 storey houses: 1 air/con unit or two? 8Apr 17, 2009 2:03 pm In situation like this we quote on either one ducted unit for around $16K or two smaller separate units for around $22K total. 2 units works better as each unit is smaller, and you can really choose what you want to run. If you have only one big unit, you will need to run lots of outlets at once. For example, you cannot just run your master bed as the airflow to this room mill be too much. With the smaller unit this is less of a problem. If you have the money the 2 separate units are a better option. Re: 2 storey houses: 1 air/con unit or two? 9Apr 17, 2009 2:46 pm In situation like this we quote on either one ducted unit for around $16K or two smaller separate units for around $22K total. 2 units works better as each unit is smaller, and you can really choose what you want to run. If you have only one big unit, you will need to run lots of outlets at once. For example, you cannot just run your master bed as the airflow to this room mill be too much. With the smaller unit this is less of a problem. If you have the money the 2 separate units are a better option. http://www.airconditioningexplained.com Thanks for that TheBoatMan Which one were your prices based one? How about a Daikin? How much would you normally quote? Hi everyone, thanks for the replies. It's an Actron Air Classic, I believe 20kw. I rang Actron themselves, I was told the system puts out 900 litres per sec air flow, and… 17 163362 Hi mate, we’re going to be another couple of years before we end up building as decided to wait and travels around Oz in our caravan, so sorry can’t you really help… 11 104203 It's a good plan and friction losses are low at low velocity. Positive displacement pumps used as header pumps are simple, reliable, have high lift and work well with… 3 34423 |
