Browse Forums Building Standards; Getting It Right! Re: Stormwater Runoff from Adjoining Property 2Nov 06, 2022 6:24 pm Document the issue with photos and video before and after rainfall. Start now and maintain it for a number of rain periods. Go to council so they can document the issue and provide your records. It’ll be a long process but any property that dosnt contain its water runoff is non compliant. The NCC, AS and likely council requirements will dictate this Re: Stormwater Runoff from Adjoining Property 3Nov 06, 2022 8:28 pm Bimbob Document the issue with photos and video before and after rainfall. Start now and maintain it for a number of rain periods. Go to council so they can document the issue and provide your records. It’ll be a long process but any property that dosnt contain its water runoff is non compliant. The NCC, AS and likely council requirements will dictate this Thank you. I have been documenting during rainfall, but definitely not before (I had some photos of after). Thanks for the advice. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 5675 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9139 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 8226 |
