Browse Forums DIY, Home Maintenance & Repair 1 Jul 02, 2022 8:11 pm Hi Folks Our little holiday home/ farm stay's brick veneer wall is coming apart. To be honest its actually been like this for a while, but I'm finally getting my act together to see how it might be fixed? Could anyone share some recommendations please on methods to fix it? Ideally not looking for a fix thats too expensive, as the house overall is a little old. Would I be able to brace it around the corner with a bracket of some sort? Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick Veneer Wall Repair Options 2Jul 02, 2022 10:00 pm Uhhhh.... you need a structural engineer to come take a look at your house as a matter of priority to determine the cause of that movement of the bottom part of the wall. Could be slab heave at that corner, even partial subsidence, but you wont know unless you get it properly assessed. Only then will you know what is required in order to fix it. Re: Brick Veneer Wall Repair Options 3Aug 03, 2022 6:35 pm Looks are like corner settlement. Have you repaired or changed the stormwater downpipe ? Re: Brick Veneer Wall Repair Options 6Aug 03, 2022 7:02 pm Most likely you we need underpinning at least the corners. Re: Brick Veneer Wall Repair Options 7Aug 10, 2022 7:13 am Hi All - Sorry for not acknowledging your reply posts - the notifications were going to my SPAM folder. Much appreciate the input. Will look to reach out to a structural engineer to see whats making it drop. Does anyone know the potential methods to fix? I know it might be subject to the actual issue causing it to drop - but is it relatively fixable? - Big Thanks again Re: Brick Veneer Wall Repair Options 8Aug 10, 2022 7:27 am Is it on sodic soil? There is a lot of mould under the eaves, is there pooling after rain? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Brick Veneer Wall Repair Options 9Aug 10, 2022 7:36 am Yes - we're looking to replace the eaves to freshen the house up. Re the soil - its fairly solid, although there is a septic tank in that area of the house/property, so I'm wondering if it might be related somehow. I'll need to head out to the property to have a closer look at the base soil conditions Re: Brick Veneer Wall Repair Options 10Aug 12, 2022 5:23 pm Because it looks like you have had significant foundation movement then your strip footing may be now cracked and more susceptible to future movement. In these cases usually underpinning will support the compromised footing but you do need to find out why it happened in the first place. Underpinnng treats a symptom(foundation movement) but doesn't fix the initial cause(ground movement). I would get a plumber to check your stormwater pipes can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5599 Hi Sleepless Knights, NOTE THE BELOW INFORMATION IS BASED ON RECOMMENDATIONS OF OTHER PEOPLE FROM FACEBOOK GROUP WHERE I POSTED THE SAME POST. I was told by few people… 9 4967 5 11202 |
