Browse Forums Renovation + Home Improvement Re: Which size dynabolts should I use? 4Mar 31, 2022 2:31 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 6Mar 31, 2022 2:47 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 8Mar 31, 2022 2:58 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 10Mar 31, 2022 3:06 pm AxeMaster Thanks. Interestingly, if you have an existing hole that is way too big, ie you accidentally drilled a 40mm hole and you want to insert an 8mm bolt, they also have a product that will fill that larger hole for you. Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 12Mar 31, 2022 3:37 pm AxeMaster A mate of mine suggested to drill a hole, fill it with liquid nails and then put the bolt in. I did something similar years back. lol I wonder if that would work, never tried liquid nails in a hole. It's pretty amazing stuff. On a gate though the fixtures are subject to some pretty decent forces as you open and close the gate, so probably wouldnt be the best idea. You could also plug the hole and use 75mm bugles. Not the most professional option but does work. And then stepping up a notch Ramsett do have a bunch of decent screw anchors, so ask you local bunnings dude Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 13Mar 31, 2022 3:47 pm One last question, really appreciate your time and help. Should I use a perforated sieve in the hole as well. So, drill the hole, put the sieve in, put in the chemset in, then the bolt. For extra grip and strenght. It's solid brick. Re: Which size dynabolts should I use? 14Mar 31, 2022 3:52 pm AxeMaster One last question, really appreciate your time and help. Should I use a perforated sieve in the hole as well. So, drill the hole, put the sieve in, put in the chemset in, then the bolt. For extra grip and strenght. It's solid brick. just drill the hole Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Which size dynabolts should I use? 18Apr 04, 2022 2:00 pm Going to get the anchor bolts and chemset from Bunnings this week. But I came across these hinges from Amazon.com.au (US stock) last night that look interesting. Don't know about what kind of weight they can hold though. Anyone seen something similar availble in Oz? I like the fact that the part that attaches to the gate is adjustable, but again don't know how much weight they can hold. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We planned a similar shower and ended up with a simple single shower with one glass panel walk into the shower at the end, much easier, dries completely between showers… 3 6361 Bigger the better for storage for me IMO. But I guess it's harder to tell the cost/benefit in your example - mainly the 'cost'? If you go 700mm, what are you doing extra… 2 3073 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3897 |
