Browse Forums Building A New House Re: Eaves on a Small block? 8Jan 10, 2022 12:47 pm I don't think you can have eaves that big? We had to have gutter on brickwork in some places as we were told the minimum gap between the fence and the house had to be 1m, and that the gap is measured from the fence to the first bit of 'house' (so to the eaves, not necessarily to the brickwork). Long story short, to have eaves would intrude into the 1m space and couldn't happen. Re: Eaves on a Small block? 9Jan 10, 2022 3:40 pm really depends on your council/estate requirements and the block size/house layout. you could have 1m eaves, if you aren't trying to use as much of the space as possible, because you're on small/narrow lot. in which case you'll probably go for standard or no-eaves option to give you more useful house space. Re: Eaves on a Small block? 10Jan 10, 2022 10:13 pm Don't forget the requirements for light and neighbouring houses. There may well be deletes of part of your eves outside your neighbours habitable windows if they are one to the boundary too. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Eaves on a Small block? 11Jun 12, 2022 11:35 pm mcbks I don't think you can have eaves that big? We had to have gutter on brickwork in some places as we were told the minimum gap between the fence and the house had to be 1m, and that the gap is measured from the fence to the first bit of 'house' (so to the eaves, not necessarily to the brickwork). Long story short, to have eaves would intrude into the 1m space and couldn't happen. Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 6344 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8805 Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 1489 |
