Browse Forums Building Standards; Getting It Right! Re: Flu vent on roof 8Oct 22, 2021 9:02 pm Not trying to be pedantic, but 'normal everyday gas' doesn't exist, it's either LPG or NG...there are others too but these are the most common and I didn't want to confuse the issue further which is why I asked, as they have different properties Here's some info that might help <https://www.elgas.com.au/blog/486-comparison-lpg-natural-gas-propane-butane-methane-lng-cng/> As the Castrol TV commercial in 1988 said...Oils ain't oils, Sol! But in your case, it's 'Gas ain't Gas, Sol' Re: Flu vent on roof 9Oct 22, 2021 9:10 pm Allnamesrgone Not trying to be pedantic, but 'normal everyday gas' doesn't exist, it's either LPG or NG...there are others too but these are the most common and I didn't want to confuse the issue further which is why I asked, as they have different properties Here's some info that might help <https://www.elgas.com.au/blog/486-comparison-lpg-natural-gas-propane-butane-methane-lng-cng/> As the Castrol TV commercial in 1988 said...Oils ain't oils, Sol! But in your case, it's 'Gas ain't Gas, Sol' Sorry for the confusion. It's not LPG because it's not bottled gas. Just the gas that Origin Energy supplies to residential properties through their gas line network. Thanks. Re: Flu vent on roof 10Oct 22, 2021 9:13 pm wagga123 Allnamesrgone Not trying to be pedantic, but 'normal everyday gas' doesn't exist, it's either LPG or NG...there are others too but these are the most common and I didn't want to confuse the issue further which is why I asked, as they have different properties Here's some info that might help <https://www.elgas.com.au/blog/486-comparison-lpg-natural-gas-propane-butane-methane-lng-cng/> As the Castrol TV commercial in 1988 said...Oils ain't oils, Sol! But in your case, it's 'Gas ain't Gas, Sol' Sorry for the confusion. It's not LPG because it's not bottled gas. Just the gas that Origin Energy supplies to residential properties through their gas line network. Thanks. ** Natural Gas ** How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6559 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5864 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6364 |
