Browse Forums Building A New House Re: Worried about Alfresco pier 2Sep 14, 2020 8:07 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Worried about Alfresco pier 3Sep 14, 2020 9:23 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Worried about Alfresco pier 5Sep 14, 2020 2:14 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Worried about Alfresco pier 6Sep 14, 2020 3:32 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Worried about Alfresco pier 8Sep 14, 2020 11:21 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Worried about Alfresco pier 10Sep 17, 2020 10:10 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Worried about Alfresco pier 20Oct 15, 2021 7:16 am This is going around in circles. It was on the plans, you signed off on it because you didn't look over them closely enough. This happens in building almost every day. The display is not what you're buying unless you've specifically specced the build as per display on everything. Life lesson. Build a brick pier around it after hand over problem solved. You'll live. Geez Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7685 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4484 |
