Browse Forums Building A New House Re: Worried about Alfresco pier 2Sep 14, 2020 8:07 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Worried about Alfresco pier 3Sep 14, 2020 9:23 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Worried about Alfresco pier 5Sep 14, 2020 2:14 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Worried about Alfresco pier 6Sep 14, 2020 3:32 pm I think you are confusing Stock Standard builders/drafting elevation details to engineers structural details The plans you are looking for should have the following The engineers name and details stamped on the plan. Cross check the Drafts mans (above) with the Engineers details For a 2S house you should have a specific plan for Engineering Columns and Beams? they should also be stamped certified by a Building Surveyor (BS) IMO that column should be steel with base plate, if its an alternate solution then it still requires the engineers Signature and BS stamp hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Worried about Alfresco pier 8Sep 14, 2020 11:21 pm The engineering Drawings forms part of the building contract documents.. you should have initialled them and received copies ? BTW, your Local Council Building department should have a complete set of the BS certified engineering as well Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Worried about Alfresco pier 9Sep 17, 2020 9:24 am StructuralBIMGuy The engineering Drawings forms part of the building contract documents.. you should have initialled them and received copies ? BTW, your Local Council Building department should have a complete set of the BS certified engineering as well I have found out that the engineers have Ok'd this plan and I have been told Metricon has done it in several house without any issues. Apparently this is treated timber for outdoor use. Now my question is, for my assurance, can I get a brick pier built around it for extra support? Can that do any damage to timber providing support? Re: Worried about Alfresco pier 10Sep 17, 2020 10:10 am The problem with you doing the brick pier is that you become second builder on the job. If something goes wrong you will be blamed even if it's not your fault. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Worried about Alfresco pier 11Sep 17, 2020 1:48 pm Is this really an issue? As far as I know any brick piers in VIC build , basically inside the brick pier is a piece of timber doing the actual support work. The bricks outside are just cladding.. However if the timber inside does fail then yeah the bricks will support it but then the section of the house will probably dropped minimum 10mm.. Don't think brick layer will lay the bricks exactly to support the main structure?? ... Re: Worried about Alfresco pier 12Oct 13, 2021 6:43 pm i am worried about same thing, when we went to the consulting sales person they showed us something nice, and we said ok if its gonna look like that, but now at the end it is exactly like yours and it looks so ugly, like elephant with bird leg. i dont know how do they approve a design like this these days, metricon should be removing these kind of ugly and stick like pillar design. just because of this i wont recommend Metricon to any one. how did you go with your alfresco pier, does it look different now or its same. Re: Worried about Alfresco pier 13Oct 13, 2021 7:21 pm Metricon assured me it is safe but I was still concerned and didn't like the look. I ended up hiring a brickie and building a brick pier around it. It looks so much better now. It cost me around $650. Got it rendered afterwards. Re: Worried about Alfresco pier 14Oct 14, 2021 9:59 pm apna235 Metricon assured me it is safe but I was still concerned and didn't like the look. I ended up hiring a brickie and building a brick pier around it. It looks so much better now. It cost me around $650. Got it rendered afterwards. No wonder they will say it is Safe, how could they design and approve such a Hideous design in 2021, you are not happy I am not happy with that pier , they told me it was going to be bit different ,like little bit raised concrete from bottom, sales person even showed me the design from Display house, when i saw that I said that looks acceptable. We trust them too much k think, We didn’t check design properly it’s too much to check. Now the piers looks Like old Man With A walking Stick. I will never go back to Metricon if they don’t Amend or change the design that looks at least acceptable I don’t like my new house even it’s not finished , and I will never recommend them as well with this kind of Hideous design I was forcing my friend to go with Metricon now I am happy they chose Someone else. When you said you hired someone to put Brick around it, does it Void the warranty or something, did you check with Metricon? Would you like to provide the photos how it looks like with the brick. Thx in advance. Re: Worried about Alfresco pier 15Oct 14, 2021 10:14 pm jung suman apna235 Metricon assured me it is safe but I was still concerned and didn't like the look. I ended up hiring a brickie and building a brick pier around it. It looks so much better now. It cost me around $650. Got it rendered afterwards. No wonder they will say it is Safe, how could they design and approve such a Hideous design in 2021, you are not happy I am not happy with that pier , they told me it was going to be bit different ,like little bit raised concrete from bottom, sales person even showed me the design from Display house, when i saw that I said that looks acceptable. We trust them too much k think, We didn’t check design properly it’s too much to check. Now the piers looks Like old Man With A walking Stick. I will never go back to Metricon if they don’t Amend or change the design that looks at least acceptable I don’t like my new house even it’s not finished , and I will never recommend them as well with this kind of Hideous design I was forcing my friend to go with Metricon now I am happy they chose Someone else. When you said you hired someone to put Brick around it, does it Void the warranty or something, did you check with Metricon? Would you like to provide the photos how it looks like with the brick. Thx in advance. This post made my eyes bleed. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Worried about Alfresco pier 16Oct 14, 2021 10:19 pm Noname jung suman apna235 Metricon assured me it is safe but I was still concerned and didn't like the look. I ended up hiring a brickie and building a brick pier around it. It looks so much better now. It cost me around $650. Got it rendered afterwards. No wonder they will say it is Safe, how could they design and approve such a Hideous design in 2021, you are not happy I am not happy with that pier , they told me it was going to be bit different ,like little bit raised concrete from bottom, sales person even showed me the design from Display house, when i saw that I said that looks acceptable. We trust them too much k think, We didn’t check design properly it’s too much to check. Now the piers looks Like old Man With A walking Stick. I will never go back to Metricon if they don’t Amend or change the design that looks at least acceptable I don’t like my new house even it’s not finished , and I will never recommend them as well with this kind of Hideous design I was forcing my friend to go with Metricon now I am happy they chose Someone else. When you said you hired someone to put Brick around it, does it Void the warranty or something, did you check with Metricon? Would you like to provide the photos how it looks like with the brick. Thx in advance. This post made my eyes bleed. I won’t sleep well, my whole life with that peers in my Mind, it’s a Nightmare. Re: Worried about Alfresco pier 18Oct 14, 2021 11:14 pm [quote="strannik":1mxzz8s6]The brick in brick piers usually isn't structural, the frame rests on the metal support inside the pier, not the brick itself.[/quote:1mxzz8s6]
Thx for the info, even if that wood pier is strongest in the world ,here I am not talking about the strength I am talking about looks of the house ,how does it look at the end.0when people build house they definitely dream of a Dream House, even it always have error or changes here and there. First thing about house or Car or anything is look , we always wish things should be eye appealing, you can just guess how does it looks Like if a Elephant has a Girlfriend Mouse, it will look odd isn’t it, That pier looks exactly like that, you can see the pic. That’s the best way I can describe my feelings about that pier.it looks so odd, I wish there was no pier rather than that pier. Re: Worried about Alfresco pier 20Oct 15, 2021 7:16 am This is going around in circles. It was on the plans, you signed off on it because you didn't look over them closely enough. This happens in building almost every day. The display is not what you're buying unless you've specifically specced the build as per display on everything. Life lesson. Build a brick pier around it after hand over problem solved. You'll live. Geez Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4550 Hi everyone, Newbie renovator here, after some advice for combining our family room in the picture and the alfresco and make a larger family room. There is a flush sill… 0 5951 |
