Browse Forums DIY, Home Maintenance & Repair 1 Apr 06, 2021 3:26 pm I'd like to add an additional TV outlet in the inside skin of a double brick wall. I understand that I'd need to drill a hole through the brickwork at the desired outlet location, connect the coax to the antenna splitter and route it to the new location (avoiding high voltage lines) and fish the cable through the cavity, then terminate the wall connector. What I'd like to know is - does there need to be a metal/plastic back box, or can I simply screw the faceplate into masonry plugs? Appreciate any replies. 5 11158 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 12913 |
