Browse Forums General Discussion Re: Cavity sliding doors 5May 25, 2020 10:35 pm I guess it comes down to the design. It seems the more modern/cleaner designs either do away with, or have a much smaller removable pelmet. Maybe the deeper ones help with draughts/sound, provided the bottom of the door seals as well? Re: Cavity sliding doors 6May 26, 2020 8:15 am 99% of cavity sliders are done that way so that any adjusting can be done by removing those pelmets and using a spanner to adjust the door up or down. The one above sticks out so much because it has been painted a different colour ( unless that is only the prime coat ). Paint it the same as the rest of the architraves etc and it will blend in and not be noticeable. Stewie We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5320 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4543 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5889 |
