Browse Forums Home Theatre & Automation Re: Data points expensive 11Jan 13, 2020 8:01 pm jacksonfunkdelhorno So far, no complaints all works as expected despite not receiving a test report for the Cat-6 cabling, I need to do this asap for peace of mind. Really, why would you want a full test report for domestic cat 6 installation. Most sparky data installers wouldnt have the expensive test gear any how to correctly certify the cable and install. Plug it in and check it works because most are only going to do a simple polarity test with a cheap $20 tester any way. or better still go to Jaycar and get yourself one. Re: Data points expensive 13Oct 19, 2020 6:14 pm Tubrgoats Sorry, maybe a silly q, But why didnt you go for Cat 7 or Cat 8 ethernet? I am doing my build now and deciding if it is worth the upgrade? Mainly, the cost. Is it worth it in a residential setting, absolutely not. Cat6a is as high as you need to go, but even Cat6 will likely be fine. I went for Cat6 because I could get them installed for $95 each, Cat6a was an upgrade to almost $150 each. If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 14023 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 21007 |
