Browse Forums Building A New House Re: Who else is building with Eden Brae? 15442Dec 22, 2019 3:25 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who else is building with Eden Brae? 15443Dec 22, 2019 11:18 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who else is building with Eden Brae? 15444Dec 23, 2019 2:26 am I have got no idea, maybe the site supervisor was pushed too hard to finish the projects and he forgot to check a few things... Cant believe I let the NBN problem passed 2.5 years and this problem for 3 years . Was always thinking that I'm using my rain water until the restriction of water come out in NSW and one of my friend said my water I use for watering the garden isnt rainwater lol Re: Who else is building with Eden Brae? 15445Dec 23, 2019 7:48 am I can't advise on NSW plumbing regulatory practices but you should check with the Department of Fair Trading to see whether a compliance certificate needed to be issued for the water tank's installation and if so, whether one was and what is stated as having been done. I take it that you did not use a building consultant to do stage inspections including PCI. You have been treated with disrespect by not having the tanks operation and maintenance requirements explained to you. You have not had first flush diverters fitted despite the notation on the hydraulic design document but I very much doubt whether they are a mandatory requirement in your area in any case. I previously noted however that the hydraulic engineer has stated that first flush diverters are required by L.G.A. but I have also noted that the hydraulic engineer's diagram depicts the infeed system installed. Do you know what L.G.A. is? Anyone who thinks that the infeed system installed also qualifies as a first flush diverter has no understanding about rainwater harvesting systems or what first flush even is. You need to check and clean the removable mesh inside the top of the wet systems vertical risers. You need to check and clean the mesh on the overflow pipes and the lower detention orifice outlets. You can access your council's Stormwater Management Plan in the link below. The doc references onsite detention systems. https://www.fairfieldcity.nsw.gov.au/si ... ent+policy I could see no reference to First Flush Diverters. Your contract will state the pump make and model plus the mains water switching device make and model. It looks like they intended fitting a Davey RainBank Evolution Mkll to the top of the tank. See video below. https://www.youtube.com/watch?v=e1pxw8gTBKw NOTE: Make sure that if the submersible pump draws water from the bottom (see one of my earlier photos), it is not placed on the tank's floor as depicted in the above video! If it is, it will vacuum sediment, deliver poor quality water and reduce the pump's life. The ffilters fitted to the RainBank Evolution Mkll (post pump) are a positive step but if a rainwater harvesting system is properly set up, filters should only be a safe guard and not the bandaid that most are. I don't recommend using RainBanks but it is your neatest option with your plumbing and tank position.and you might get lucky with longevity. As far as the detention system goes, it is operational and would satisfy the council's requirements. Also check to see whether there is a balance line fitted between the two tanks. It should be about 100mm above the ground. You also need to measure the distance between the tank's protruding pipe work and the fence to see if it complies with the minimum 450mm setback requirement. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who else is building with Eden Brae? 15446Dec 23, 2019 1:42 pm the builder has got their own independent inspector and on the handover date, I paid $550 for an difference independent inspector who has been referred to me by one of the member here. The funny thing were, both of them didn't find out these 2 problem ( my NBN conduit has been put under their brick walls ,and this water-tank thing...) What a waste of money !! The good news I just get from Eden Brae Homes is they admitted their mistake, and telling me they already contact the water tank company to com and install a switch controller . They didn't mentioned about the pump, but I'll need to talk to their trade when he comes after new year. I will ask him about the first flush, the pump location and stuff. appreciated your helps SaveH20. will keep you updated. Have a merry Xmas and happy new year Re: Who else is building with Eden Brae? 15447Dec 23, 2019 2:05 pm Re the first flush, the 900mm head is a council requirement, a first flush diverter cannot be fitted to the downpipe. Stipulating a set 900mm head is amateurish at best. The detention drainage is designed for a 1:100 ARI. A 1:100 ARI has about 50% more intensity than a 1:20 ARI EDIT: Of interest, does your site have an impervious area greater than 70%? Your council requires any residential site with an impervious area exceeding 70% to have an onsite detention system. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who else is building with Eden Brae? 15448Dec 26, 2019 4:50 pm dreamh0me We got an email today saying: I have am currently working now with our Hydraulic engineering to prepare your hydraulic stormwater design. One thing I would like you to confirm is your preference on either 1. Below ground modular tank for OSD - Or – 2. An above ground basin We have noted we would be obtaining a design for an above ground design as this is usually the standard however you do have the option of either. Unfortunately at this stage I could not provide the cost difference until we get back your design and send away for quotes but normally the below ground system is the more expensive. If you have a look at our Hydraulic engineers website on the two types of systems and let me know what your preference is. http://www.stormwater.net.au/on-site-detention.html We are building in Ku ring gai. I am confused whether to go above or below ground. Can anyone advise me on pros and cons and what price to expect to pay? Did you have any problem with getting the back balcony approved with Ku Ring Gai council? We are also planning to build Windsor a similar plan with opal facade. Re: Who else is building with Eden Brae? 15449Dec 26, 2019 5:53 pm SaveH2O Re the first flush, the 900mm head is a council requirement, a first flush diverter cannot be fitted to the downpipe. Stipulating a set 900mm head is amateurish at best. The detention drainage is designed for a 1:100 ARI. A 1:100 ARI has about 50% more intensity than a 1:20 ARI EDIT: Of interest, does your site have an impervious area greater than 70%? Your council requires any residential site with an impervious area exceeding 70% to have an onsite detention system. I don't know if my site is an impervious area or not, but only my block ( out of 6 blocks ) required that detention system. I was asking them why I had to have that system and the answer was, that is requirement for my house to be built after the hydraulic check by builder engineer. They gave me only 7 days to accept that variation or my build would be delayed. I chose to signed, didn't want the build to be more delayed. Re: Who else is building with Eden Brae? 15450Dec 28, 2019 10:29 pm Hi, for those who have upgraded their bricks THEN decided to render your facade - was your brick upgrade price revised down in cost as they use common bricks under render because they’ll be covered up anyways? Re: Who else is building with Eden Brae? 15451Dec 29, 2019 9:47 pm Homedreams2019 Hi, for those who have upgraded their bricks THEN decided to render your facade - was your brick upgrade price revised down in cost as they use common bricks under render because they’ll be covered up anyways? Absolutely it should be credited back Cheers Brickface Re: Who else is building with Eden Brae? 15452Jan 02, 2020 7:46 pm Thanks brickface, This is also what I thought however we’ve been told ‘it’s actually more expensive to render the common bricks’... will be pushing back on this for sure. Brickface Homedreams2019 Hi, for those who have upgraded their bricks THEN decided to render your facade - was your brick upgrade price revised down in cost as they use common bricks under render because they’ll be covered up anyways? Absolutely it should be credited back Re: Who else is building with Eden Brae? 15453Jan 09, 2020 4:53 pm SaveH2O I can't advise on NSW plumbing regulatory practices but you should check with the Department of Fair Trading to see whether a compliance certificate needed to be issued for the water tank's installation and if so, whether one was and what is stated as having been done. I take it that you did not use a building consultant to do stage inspections including PCI. You have been treated with disrespect by not having the tanks operation and maintenance requirements explained to you. You have not had first flush diverters fitted despite the notation on the hydraulic design document but I very much doubt whether they are a mandatory requirement in your area in any case. I previously noted however that the hydraulic engineer has stated that first flush diverters are required by L.G.A. but I have also noted that the hydraulic engineer's diagram depicts the infeed system installed. Do you know what L.G.A. is? Anyone who thinks that the infeed system installed also qualifies as a first flush diverter has no understanding about rainwater harvesting systems or what first flush even is. You need to check and clean the removable mesh inside the top of the wet systems vertical risers. You need to check and clean the mesh on the overflow pipes and the lower detention orifice outlets. You can access your council's Stormwater Management Plan in the link below. The doc references onsite detention systems. https://www.fairfieldcity.nsw.gov.au/si ... ent+policy I could see no reference to First Flush Diverters. Your contract will state the pump make and model plus the mains water switching device make and model. It looks like they intended fitting a Davey RainBank Evolution Mkll to the top of the tank. See video below. https://www.youtube.com/watch?v=e1pxw8gTBKw NOTE: Make sure that if the submersible pump draws water from the bottom (see one of my earlier photos), it is not placed on the tank's floor as depicted in the above video! If it is, it will vacuum sediment, deliver poor quality water and reduce the pump's life. The ffilters fitted to the RainBank Evolution Mkll (post pump) are a positive step but if a rainwater harvesting system is properly set up, filters should only be a safe guard and not the bandaid that most are. I don't recommend using RainBanks but it is your neatest option with your plumbing and tank position.and you might get lucky with longevity. As far as the detention system goes, it is operational and would satisfy the council's requirements. Also check to see whether there is a balance line fitted between the two tanks. It should be about 100mm above the ground. You also need to measure the distance between the tank's protruding pipe work and the fence to see if it complies with the minimum 450mm setback requirement. your right SaveH2O . Got an email that they are about to install a Kingspan water evolution MK3, and saying this is the best option. Otherwise, they have to dig and cut the concrete to install the pump on the ground which will take much of my space . Cheers Steven Re: Who else is building with Eden Brae? 15454Jan 09, 2020 5:05 pm I hope that it goes well for you. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who else is building with Eden Brae? 15457Jan 11, 2020 2:00 am sbanu Has anyone built a Cremorne 35 with Eden Brae?if yes would love to see a few photos of the finished house please !! we have what are you interested in? Re: Who else is building with Eden Brae? 15458Jan 11, 2020 9:57 am Cremorne35 sbanu Has anyone built a Cremorne 35 with Eden Brae?if yes would love to see a few photos of the finished house please !! we have what are you interested in? Hi Cremone 35 ThAnks for your reply . I just wanted to get an idea of what the house looks like completed . The display house is very basic with poor colour Choices . We’re making a few changes to the kitchen and master bedroom . But I just wanted to see how it would look with some different colour Scheme s. I can send you my email address if you would Mind sharing a few pics pls. Also how was your experience building with them and roughly how much should I budget For in upgrades with this design . Thanks Re: Who else is building with Eden Brae? 15459Jan 15, 2020 3:11 pm NSharma Woo Hoo!! Just received an email that our job has been released to site today!! 13 days after finalising all the admin We were getting so antsy! How long does it usually take now for them to begin? SS - Robert Miller. Anyone have/had him? Hi N Sharma Did you work with Robert? How was his work? Regards, Mark I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 24052 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226283 |
