Browse Forums General Discussion Re: Outdoor Spa - Need plumbing & electrical connections?? 5Aug 17, 2007 3:52 pm You fill it (and top it up occasionally) with a hose.
By law, it must be in a fenced enclosure, or be fitted with a lockable cover that is child resistant (never say child-proof - they'll find a way!). They must also be hardwired by law as well - but this is only at local government level, and your council may or may not follow this. Our council insists on hardwiring (32A circuit, minimum 4mm sq cable) back to the meter box and the fitment of an ELCB (earth leakage/safety switch). You are supposed to apply for a permit to install one (99.9% of people don't) and council will inspect the slab or location to ensure it can take the weight of a water-filled spa, as well as inspecting the electrical installation, and the fencing/cover. I installed my own spa. with the help of a licenced sparky. Basically layed a 100mm slab with F72 reo in it, located it, ran the conduit & wire, and had the sparky connect each end. Mine also has a 20A ELCB in the 'works' of the spa as well.. In-laws did theirs the same way, and no probs with council. If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4831 Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 5251 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6374 |
