Browse Forums Building A New House Re: Using exposed brick for a feature wall 11Jan 20, 2019 10:38 am Bebbsy Unfortunately our builder, Statesman Homes, informed us that exposed brick walls are not an option if we build with them. Very disappointed. And the reason is "the Slab and footing Engineering will need upgrading" The cost of brickwork is relatively cheap if you have the Correct Footings specified...hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Using exposed brick for a feature wall 12Jan 20, 2019 10:40 am StructuralBIMGuy Bebbsy Unfortunately our builder, Statesman Homes, informed us that exposed brick walls are not an option if we build with them. Very disappointed. And the reason is "the Slab and footing Engineering will need upgrading" The cost of brickwork is relatively cheap if you have the Correct Footings specified...hth We would have paid for the slab to be upgraded but were not given the choice. 😟 Re: Using exposed brick for a feature wall 13Jan 20, 2019 2:13 pm Bebbsy Unfortunately our builder, Statesman Homes, informed us that exposed brick walls are not an option if we build with them. Very disappointed. Maybe a blessing. There’s so many cool looking wallpapers these days, they would be a better option than committing to an actual brick wall and associated cost. Plus if you ever grow tired of it just replace it or remove and paint. Re: Using exposed brick for a feature wall 14Jan 20, 2019 7:22 pm Bebbsy We’re In the process of finalising our house plans and now considering an exposed brick feature wall in the living room, more than likely on the wall where the TV will be located. Have you seen the latest trend in TV screens? They are the wall. Check out CES 2019 held a few weeks ago. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Using exposed brick for a feature wall 15Jan 20, 2019 9:35 pm SaveH2O Bebbsy We’re In the process of finalising our house plans and now considering an exposed brick feature wall in the living room, more than likely on the wall where the TV will be located. Have you seen the latest trend in TV screens? They are the wall. Check out CES 2019 held a few weeks ago. Hmmm, see what you mean. 😀 very, very impressive. Re: Using exposed brick for a feature wall 16Jan 20, 2019 10:25 pm Bebbsy Unfortunately our builder, Statesman Homes, informed us that exposed brick walls are not an option if we build with them. Very disappointed. Have you asked them why? Ask them to provision the footing at least, you can always build it the wall after handover. Re: Using exposed brick for a feature wall 17Jan 21, 2019 10:42 pm alexp79 Bebbsy Unfortunately our builder, Statesman Homes, informed us that exposed brick walls are not an option if we build with them. Very disappointed. Have you asked them why? Ask them to provision the footing at least, you can always build it the wall after handover. We did discuss that but my other half was not convinced, so we dropped the idea. Just going with gyprock walls now. Re: Using exposed brick for a feature wall 18Jan 21, 2019 11:34 pm You could always go for these brick faces from Austral bricks. Will give you the look your after. https://australbricks.com.au/vic/produc ... ?facings=1 Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Using exposed brick for a feature wall 19Jan 22, 2019 12:36 am chippy You could always go for these brick faces from Austral bricks. Will give you the look your after. https://australbricks.com.au/vic/produc ... ?facings=1 Thank you. I’ve not seen these before, will definitely check them out at the Austral Display centre. Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 11183 hmmm id assume youll get hit with the "natural product therefore variation in colour etc" excuse. How bad are we talking? One could argue that if none of the displays or… 3 2565 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10704 |
