Browse Forums Flooring & Floor Covering Re: Tiler damaged balcony tile...how to fix? 4Sep 27, 2018 8:22 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Tiler damaged balcony tile...how to fix? 5Sep 28, 2018 6:45 am SaveH2O You have responded to poor advice from a serial spammer. Yes, to improve the advice so the OP doesn’t just smash the tile with a hammer and ruin every tile around it in the process. Edit: that said, the one time poster probably hasn’t been back to read it anyway. Re: Tiler damaged balcony tile...how to fix? 6Sep 28, 2018 9:01 am arcadelt Yes, to improve the advice so the OP doesn’t just smash the tile with a hammer and ruin every tile around it in the process. Oops! My bad. This particular forum spammer has had a free ride on various threads for some time, probably because the reporting process is not prominent. I'll send an improvement suggestion to Homeone. For members reading this, each post has a row of three (very light) dots in the bottom right hand corner. Clicking on this will bring up another ((light coloured) box that includes Report Post. Clicking Report Post will bring up a more prominent box that allows the post to be reported and the reason why. Reporting forum spam early will result in earlier deletion and less repeat spam in other threads. There has been a lot of spam lately. Forum advertisers are identified by having an orange coloured member's name above their avatar and it is this revenue stream that offsets a large part of the expenses incurred in running the forum. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2492 The coupling, which is made from flexible PVC, needs to comply with AS/NZS 4327 which specifies the requirements for metal banded flexible couplings used in low-pressure… 1 2268 Thanks, we are headed in the direction of grinding, but unsure of what to do on top of that? 2 2568 |
