Browse Forums Building A New House Re: Building with Metricon 7550Jul 26, 2018 9:46 pm peterivory shokel1975 Thanks everyone. I guess we are signing on Saturday! My only concern now is that once they have our signatures and our 5% deposit, we lose our ability to play hardball and try to negotiate the increases in some of the prices. I feel they will be less likely to agree to honour the original prices in the Prelim Contract if we have already signed and paid. Just some of the things we are questioning are: Site Cut & Fill was $2674 in PC - now $2750 (this is not a huge increase, but why has it increased at all?) Water tank was $7430 in PC - now $7800 Cost to have brickwork above garage roller door was $400 in PC - now $1070! Two new charges for windows that were never in Quote or PC Large mirror in Bathroom was $500 in PC - now $1093! Can't understand why some of these are such big changes.... we feel they should honour prices in PC. As a bricklayer I’ll tell you strait out we get paid about 150 to lay over the garage lintel at the most. These scumbags are ripping you off It’s absolute BS isn’t it.... Re: Building with Metricon 7551Jul 26, 2018 10:48 pm peterivory shokel1975 Thanks everyone. I guess we are signing on Saturday! My only concern now is that once they have our signatures and our 5% deposit, we lose our ability to play hardball and try to negotiate the increases in some of the prices. I feel they will be less likely to agree to honour the original prices in the Prelim Contract if we have already signed and paid. Just some of the things we are questioning are: Site Cut & Fill was $2674 in PC - now $2750 (this is not a huge increase, but why has it increased at all?) Water tank was $7430 in PC - now $7800 Cost to have brickwork above garage roller door was $400 in PC - now $1070! Two new charges for windows that were never in Quote or PC Large mirror in Bathroom was $500 in PC - now $1093! Can't understand why some of these are such big changes.... we feel they should honour prices in PC. As a bricklayer I’ll tell you strait out we get paid about 150 to lay over the garage lintel at the most. These scumbags are ripping you off We've got a 5.5m opening with 4 courses of bricks over it... Just curious Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building with Metricon 7552Jul 26, 2018 10:49 pm shokel1975 Water tank was $7430 in PC - now $7800 I would love to see the specs on that installation!!! Is it an underground tank? Rip offs in this area are common, I have seen similar prices before but none were justified. Unfortunately, nearly all of the installs that I see are overpriced, sub standard, often not compliant and/or void manufacturer's warranties. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building with Metricon 7553Jul 26, 2018 11:03 pm SaveH2O shokel1975 Water tank was $7430 in PC - now $7800 I would love to see the specs on that installation!!! Is it an underground tank? Rip offs in this area are common, I have seen similar prices before but none were justified. Unfortunately, nearly all of the installs that I see are overpriced, sub standard, often not compliant and/or void manufacturer's warranties. Not underground.... 5000lt slimline tank. Need it to be installed with build as a requirement of council. Re: Building with Metricon 7554Jul 26, 2018 11:35 pm NthHome Hi All I upgraded to the largest daikin air conditioning unit - it’s huge and very good but very loud! The neighbours have been complaining and it’s starting to get nasty. I tried installing sound insulation materials that I bought from the below company but hat has been useless. http://thesilencer.com.au/air-condition ... roofing-2/ Is anyone in the same boat and what did they do? The fan noise is that main issue. Re: Building with Metricon 7555Jul 27, 2018 7:48 am shokel1975 Not underground.... 5000lt slimline tank. Need it to be installed with build as a requirement of council. A metal slimline costs about $2k minimum plus the builder's usual 20% mark up. It can easily come to $3k. The slab could be about $500. Pumps are usually unnecessarily oversized (cisterns fill at about 6 lpm) and consequently expensive and if the installer is a Davey dealer, you will almost certainly be given an expensive Rainbank automatic mains water switching device when there are better and cheaper options available. All up, the basics above could come to $5 plus labour and some other fittings including the electrical socket outlet aka gpo. To meet the Victorian 6 star requirement, the water tank must be serviced by a minimum 50 sq m roof catchment area. The "roof catchment area" is size factored to the roof slope which accounts for wind driven rain. If you have the standard 23 degree roof slope and the standard 115mm quad slotted guttering, a minimum of two downpipes will require diversion which means that the second remote downpipe diversion will entail a wet system that requires trenching and additional labour costs. It is easy to halve these costs with a little know how and product knowledge but it rarely happens unfortunately. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Building with Metricon 7556Jul 27, 2018 12:28 pm shokel1975 SaveH2O shokel1975 Water tank was $7430 in PC - now $7800 I would love to see the specs on that installation!!! Is it an underground tank? Rip offs in this area are common, I have seen similar prices before but none were justified. Unfortunately, nearly all of the installs that I see are overpriced, sub standard, often not compliant and/or void manufacturer's warranties. Not underground.... 5000lt slimline tank. Need it to be installed with build as a requirement of council. And tight up against an exterior wall???? Re: Building with Metricon 7557Jul 27, 2018 1:04 pm We have it at rear of our brick shed/garage in backyard Re: Building with Metricon 7559Jul 31, 2018 6:33 pm Hoping for some advise - I am having issues with Metricon refusing to fix an issue with the shower in my main bathroom. I have had a strip drain installed, and in some sections the tiling is slightly lower than the edge of the strip drain so the water does not fully drain from the shower floor, resulting in water pooling along the tiles on the edge of the drain and the grout going mouldy quickly and needing scrubbing constantly. Metricon have have provided me a letter stating they will not fix this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ To me, a shower that cannot fully drain cannot possibly be "built to code". They had their inspector come out who said the fall is correct and in his opinion the drain is below the level of the tiles. Video of the problem is here: https://drive.google.com/file/d/1DMPZV0 ... sp=sharing Any suggestions on what my options are? Anyone suggest what I can do to fix this problem as Metricon SA have washed their hands of it and refusing to do anything. Their entire after sales service has been pretty disorganized and unresponsive. Re: Building with Metricon 7560Aug 01, 2018 7:00 am lincoln32 Hoping for some advise - I am having issues with Metricon refusing to fix an issue with the shower in my main bathroom. I have had a strip drain installed, and in some sections the tiling is slightly lower than the edge of the strip drain so the water does not fully drain from the shower floor, resulting in water pooling along the tiles on the edge of the drain and the grout going mouldy quickly and needing scrubbing constantly. Metricon have have provided me a letter stating they will not fix this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ To me, a shower that cannot fully drain cannot possibly be "built to code". They had their inspector come out who said the fall is correct and in his opinion the drain is below the level of the tiles. Video of the problem is here: https://drive.google.com/file/d/1DMPZV0 ... sp=sharing Any suggestions on what my options are? Anyone suggest what I can do to fix this problem as Metricon SA have washed their hands of it and refusing to do anything. Their entire after sales service has been pretty disorganized and unresponsive. Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12822 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9730 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19780 |
