Browse Forums Building A New House Re: Projects to do after New Home Handover 21May 05, 2018 7:52 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover- Garage Roof Stor 22May 09, 2018 11:02 am All progress pics are in the first post - https://forum.homeone.com.au/viewtopic.php?f=31&t=89917&p=1761154#p1761154 Re: Projects to do after New Home Handover 24May 09, 2018 3:08 pm Thanks for the feedback I'll put up a simplified flowchart Have you Truss or Pitched frame roofs? The later is preferable Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 25May 09, 2018 3:45 pm Hi StructuralBIMGuy, But if I plan to have a storage zone under standard pitched residential roof (hip&valley style) over 250 mm ceiling joists, do I need any "special" trusses there? One option I am considering is to cover ceiling joists with load bearing XPS, however, roof design probably have to be done to maximise the under roof space? Thanks WBR, Alex Re: Projects to do after New Home Handover 26May 10, 2018 9:40 am Hi Alex79 I doubt you will need additional floor trusses for 250mm joists/beams.. but it depends on the span and loading If you have the engineering properties/ span tables for XPS great then it's easy to check flooring suitability Correct...It's thickness also decreases the overall usable height, but for storage over a garage neither insulation nor exposed beams are considerations, but rather location, cost, height and the ability to have a number of ceiling access points. If you intend on building a loft then it will require a different engineering design, considerations & methodology. OT..Generally ceiling joists are 90 x 45 with at least 2 continuous spans over walls & under hanger beams & lined beneather. Lining them on the top with plasterboard or a structural flooring material indicates an exposed beam/loft structure? I intend putting info up on Considerations and Methodologies cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 27Jun 01, 2018 1:34 pm What I've been thinking about is hanging sliding barn doors to my media. I don't have enough internal space for CSD and I didn't want swinging doors on there. Ive searched a bunch of info and it seems like a pretty simple DIY job. The only issue I may have is attaching the slider to the floor tiles to ensure the door doesn't flap round.... Pic for reference Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All progress pics are in the first post - https://forum.homeone.com.au/viewtopic.php?f=31&t=89917&p=1761154#p1761154 Re: Projects to do after New Home Handover 28Jun 02, 2018 8:42 am Hi BrentandAllison Rebate the door edges in the middle & the ends try a Groove and Door Guide on the bottom edge Cowdroy Door Track Systems hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 29Jun 10, 2018 12:42 pm I've have received several messages about Double Carports Designs, Data & Quants So here is a different BIM format and I've included info regarding Manufacturers details for important Timber Connections If you have any questions please post back or leave a PM Cheer Chris Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 30Jun 18, 2018 10:38 am I'm hoping to get some advice as to the options for garage flooring protection. We'll be doing a bunch of crafty/hobby/sport/maintenance stuff in out 3 car garage. So things like paint/oil spills are a possibility - NO - certainty. Paint? Seal with something? Cover? Oh and of course - there will be cars in there Cheers B&A All progress pics are in the first post - https://forum.homeone.com.au/viewtopic.php?f=31&t=89917&p=1761154#p1761154 Re: Projects to do after New Home Handover 31Jun 19, 2018 8:41 pm Hi BrentandAllison 3 Car Garage sounds great..The extra garage space is priceless I would recommend concrete etching, primer & 2-pack epoxy paint Here are my tips Stick to major manufacturers of well known Brands Check out 3 brands, most have "How to.." videos on their websites and buy it while on promotion or shop around I would allow the concrete a good 6 months to cure, look for any damp spots during the wet months, fix, allow to dry..then paint Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 32Jun 20, 2018 2:05 pm What about doing the whole flooring post-handover, reading a few forums builders put a heavy mark up on flooring. Is it a good idea to get an independent tiler, carpet layer to do flooring post build Re: Projects to do after New Home Handover 33Jun 20, 2018 2:23 pm CS199 What about doing the whole flooring post-handover, reading a few forums builders put a heavy mark up on flooring. Is it a good idea to get an independent tiler, carpet layer to do flooring post build We have elected to do this with main floor tiling and carpets. The builder could not offer tiles we liked. Doing the carpet ourselves has allowed up to upgrade the underlay at pretty much no extra cost. Plus saving the 20% markup is always a little bonus All progress pics are in the first post - https://forum.homeone.com.au/viewtopic.php?f=31&t=89917&p=1761154#p1761154 Re: Projects to do after New Home Handover 34Jun 25, 2018 3:06 pm I've decided that instead of the barn doors for the media - I'll build a vertical timber slatted partition wall. While it looks simple, I'm assuming that building off site - out the back and bringing it in and then trying to stand it up would be the tricky part. Having it floor to ceiling - with the angle of the top beam scraping along the roof etc.. I'd like some advice on how they are usually build and installed. If you know that is All progress pics are in the first post - https://forum.homeone.com.au/viewtopic.php?f=31&t=89917&p=1761154#p1761154 Re: Projects to do after New Home Handover 35Jun 26, 2018 6:15 am BrentandAllison Having it floor to ceiling - with the angle of the top beam scraping along the roof etc.. I'd like some advice on how they are usually build and installed. If you know that is Search google for an image to link/post or please post a rough sketch Removable internal partition systems Might provide a solution for a screen that can easily to knock up and down if later required? hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 36Jun 26, 2018 8:26 am StructuralBIMGuy BrentandAllison Having it floor to ceiling - with the angle of the top beam scraping along the roof etc.. I'd like some advice on how they are usually build and installed. If you know that is Search google for an image to link/post or please post a rough sketch Removable internal partition systems Might provide a solution for a screen that can easily to knock up and down if later required? hth Cheers Here is an idea of what I was thinking of - Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All progress pics are in the first post - https://forum.homeone.com.au/viewtopic.php?f=31&t=89917&p=1761154#p1761154 Re: Projects to do after New Home Handover 37Jun 28, 2018 9:12 am BrentandAllison Thanks for the photo..Nice Feature This can be Installed DIY, DI4Me, DIL8er,etc further points to consider
Cheers Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 38Jul 05, 2018 11:07 am Just out of curiousity has anyone built/bought any A/C unit shrouds to essentially hide and beautify the units sitting up against the house? We have a very narrow block so dont really have anywhere to hide it so to speak so it will be clearly visible from our laundry. I was thinking of designing something for it to blend into the house which will offer some protection to the unit but also adequate airflow also. Re: Projects to do after New Home Handover 39Jul 05, 2018 11:39 am Dr-Jekl That is definitely a CFD Multiphysics Simulation app begging to be developed , involving Airflow, Noise reduction, Heat transfer,etc Photo, unit size, dBs, Orientation, more info? Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Projects to do after New Home Handover 40Jul 05, 2018 11:42 am Think like those grates they put in front of fire place . Sorry I don't know what they are called. You can do a small wood box with cuttings to hide https://aristair.com/blog/15-creative-w ... nditioner/ 0 2266 Any advice on a builder in NSW who is demanding an extra 22000k after the house is completed and contract paid in full .Standard HIA contract. Never received a variation.… 0 20829 I can help you with all that, you can PM me with details if you wish 3 6051 |
