Browse Forums Building Standards; Getting It Right! Re: Very noisy steel frame house 3Feb 12, 2018 7:41 pm Hi krushull That has also been discussed here Do your upstair walls of double storey homes make noises? BTW photos also help Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Very noisy steel frame house 5Feb 13, 2018 1:51 pm krushull In light of the cracking sounds when it's windy. You might want to have the wind classification & shear wall engineering bracing drawings checked do you have photos of the framework whist the house was under construction? hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Very noisy steel frame house 6Feb 26, 2018 7:02 pm Thanks all, sorry for the slow response. We are getting an engineering report done this week to check out the cracks and the noise so hopefully that will shed some light on things. It's not so much when it's windy although I do notice it then a lot. Usually the change in temperature really kicks it off. Unfortunately we do not have photos of the frame when it was being built. Re: Very noisy steel frame house 7Oct 15, 2019 9:10 pm Krushull Thanks all, sorry for the slow response. We are getting an engineering report done this week to check out the cracks and the noise so hopefully that will shed some light on things. It's not so much when it's windy although I do notice it then a lot. Usually the change in temperature really kicks it off. Unfortunately we do not have photos of the frame when it was being built. Krushull, what builder was this? I PM'ed you. Re: Very noisy steel frame house 8Oct 20, 2020 11:18 pm Krushull Thanks all, sorry for the slow response. We are getting an engineering report done this week to check out the cracks and the noise so hopefully that will shed some light on things. It's not so much when it's windy although I do notice it then a lot. Usually the change in temperature really kicks it off. Unfortunately we do not have photos of the frame when it was being built. Which builder is that? Re: Very noisy steel frame house 9Aug 08, 2021 12:49 pm Krushull Thanks all, sorry for the slow response. We are getting an engineering report done this week to check out the cracks and the noise so hopefully that will shed some light on things. It's not so much when it's windy although I do notice it then a lot. Usually the change in temperature really kicks it off. Unfortunately we do not have photos of the frame when it was being built. Hi Krushall. Have there been any updates? I'm having a very similar issue with my property. I've also sent you a PM. Thanks! Re: Very noisy steel frame house 10Oct 10, 2021 11:49 am yesplease Krushull Thanks all, sorry for the slow response. We are getting an engineering report done this week to check out the cracks and the noise so hopefully that will shed some light on things. It's not so much when it's windy although I do notice it then a lot. Usually the change in temperature really kicks it off. Unfortunately we do not have photos of the frame when it was being built. Hi Krushall. Have there been any updates? I'm having a very similar issue with my property. I've also sent you a PM. Thanks! I recently built a double storey steel frame house, and having exactly same issues. Like in the morning when anyone walks on the floors upstairs that haven’t been walked yet, the floor and walls make creaking sounds but that settles when walked upon 1-2 times. However, when someone walks upstairs I can hear floor creaking sounds downstairs. Its a brand new house less than 12 months old. But builder says it’s normal as steel frame/floors do have more flex than timber. But honestly not buying their argument. Can anyone suggest any solution or way forward to deal with this issue or with builder? Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14892 This is 100% true. You can not hang anything on steel frames. very frustrating 8 10236 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 9179 |
