Browse Forums General Discussion Re: Stormwaters and Water Tanks - total $46,350 2Oct 31, 2017 6:07 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 5Oct 31, 2017 6:36 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 8Nov 01, 2017 7:41 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwaters and Water Tanks - total $46,350 13Nov 11, 2017 9:45 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwaters and Water Tanks - total $46,350 14Nov 11, 2017 9:52 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 15Nov 11, 2017 9:58 am Hi H2O - not necessarily. We didn't stop the tanks being compulsory - the "powers that be" decided - after weighing up all the factors - that the "savings" were actually not there. The building - plastics, power used before and after, etc - meant there was no "REAL" savings in eco terms. It wasn't me - honest ! Tanks are therefore not necessary anymore - at least here. Re: Stormwaters and Water Tanks - total $46,350 16Nov 11, 2017 9:58 am Oops - I meant no longer "compulsory" ... Re: Stormwaters and Water Tanks - total $46,350 17Nov 11, 2017 10:11 am LoOve the irony "Detention tanks"... still, thats no excuse to rip off the Battlers & Punters because Council stormwater infrastructure systems are inadequate It's no wonder you guys can't afford housing Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Stormwaters and Water Tanks - total $46,350 18Nov 11, 2017 11:06 am Saint Mike - the "powers that be" decided - after weighing up all the factors - that the "savings" were actually not there. The primary focus should be on saving a precious resource, not on saving money but done correctly, both aims can be achieved. Cost wise, people get ripped off by the installers that the builders are in bed with, not only on cost but also by poor product choices and endemic substandard installations. Regulations are also stuck in the dark ages...or at least pre Millennial drought times. Big water savings use to be had by plumbing to the toilets but there were single flush 12 L cisterns back then, now new homes have low volume dual flush cisterns. It would still be worthwhile plumbing stored rainwater to cisterns if not for nearly all installations being unnecessarily expensive either due to greed (commercial tie ins with expensive products), lack of knowledge or lack of care. Unknowledgeable bureaucrats then decide that the idea itself is bad. Plumbing filtered rainwater to a HWS is now the best utilisation for the harvested resource. It is ironic that expensive detention systems are specified when ground water levels are falling because of the obscenely high % of suburban impervious area that of course also includes roads. Why not have groundwater recharge points that accept filtered stormwater overflows from a retention tank instead? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Stormwaters and Water Tanks - total $46,350 19Nov 20, 2017 7:01 pm I feel your pain. In the Northern Beaches area, our stormwater is costing us 33k+ (not including the rainwater tanks). The council is forcing us to do above ground/surface detention. So we have to put around our land a 50-60+m waterproof, masonary retaining wall. We went from a 15k PA (for stormwater OSD) to 33k+, probably more, as we will probably have to rip down and existing retaining wall. Re: Stormwaters and Water Tanks - total $46,350 20Dec 02, 2017 9:45 am rdcool Home_17 rdcool Yes, for any buildings a 10,000L underground water tank is required. For existing dwellings, above tank can be used. Which council are you building in? How big for you site coverage? We received the notice from builder which said storm water consultant suggested us accommodate 12000L water tank. We are told by consultant that council requires OSD for all new dwellings and our site coverage exceeds 35%.The raintanks will be partially used for internal re-use and the balance for OSD. But our BASIX only requires at least 3000L water tank. So is it possible which we can reduce size for the water tank? T Thank you. I am with Willoughby council, they require a 10000L undergrond tank for new buildings. Apparently the most costly items are the absorption trench and concrete version of the tank. Do you have to have an absorption trench? Did they quote you a price yet? I am in a similar boat, and I have been quoted $33,000 for hydraulics set up. My tender had a PA for 17K and was advised that was on a higher side!! Its interesting how the actual tender quote came up lower compared to original provisional quote, and that was used a selling tact/example by CSR to demonstrate how builders surprise customers by always putting provisions at higher side and customers end up saving money. But since the date contract/tender was signed - everything has been opposite and costing more! Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 18319 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 9117 |
