Browse Forums Building A New House Re: Rawson Homes - General Thread 82Jan 08, 2017 5:43 pm Follow our build: http://dandsbenham21rawsonhomesbuild.weebly.com/ Re: Rawson Homes - General Thread 98Jan 23, 2017 5:59 pm The kitchen design was pretty lacklustre, to be honest. I'd suggest going in with a very good idea of what you want because you probably won't get much guidance. With other stuff, we pretty much said 'we don't like the standard option, what else can we have' (though we liked the lollipop taps ) Re: Rawson Homes - General Thread 99Jan 23, 2017 6:19 pm anonymous- AJW anonymous- Would you guys have a list of available internal upgrades? I have my internals appointment in the next few weeks and was hoping to take a look at some of the items I can upgrade to. I'm not a fan of the tapware (as an example) and wouldn't mind seeing what is available as an upgrade. Well if you don't have a lux package then look at the lux package details to get an idea of what is on offer. If you have lux and want something else then you tell them what you want and they will price it Generally best to keep within the same brands as they give them volume discounts but end of day they will price anything you want. Thanks red15 and AJW. I do have the lux package indeed but having seen the tapware in the display homes (the bathroom and laundry ones look a bit like lollipops and have large surrounding plates) I was hoping to upgrade to something a bit more sleek. I wasn't sure if they source these direct from the manufacturer or go through a retail/specialist store (like Beacon for the lighting and Elba for cabinetry) which would then be the "limit" of what I can choose. For those who have gone through the process, how does it work? Do you provide model numbers of the upgrades you would like to have and they price these up in the form of variations and get back to you? How does the kitchen cabinetry design work? I'm assuming they give you a pre-designed kitchen and you can mix and match the number of draws, draw sizes, shelving etc to your liking. Something's like lights they do go through beacon for. But they have a standard range programmed into Clipsec which they use to select and anything else you specify. With taps just tell them the model you want and be as exact as you can (part numbers) to ensure it is what you want. With taps pay particular attention to finishes as these change the part numbers. Kitchen selection was ordinary to say the least. What I did was my own plan and said I want this. Other than that bog standard design for the given house with options such as soft close, handless etc thrown in. I much preferred the procsss in my old place where I was given a kitchen allowance and told to make an appointment with the joinery company and pay them anything above the allowance. I also specified my own door type (they used Corinthian) and specified my door furniture (Gainsborough). Roller doors they use B&D again knew what I wanted before selection. So if anything best advice is know what you want before you go! Re: Rawson Homes - General Thread 100Feb 01, 2017 7:25 am Hi All Hoping someone can provide some advice... We are building a Balmoral and have noticed that our flashing has been done incorrectly in some places. In the places where second story brickwork meets a first story roof - the flashing has been done too high so it doesn't sit nicely on top of the first storey tiles so the water will not run off. you can see in the picture below it actually doesn't even meet the roof at all When we asked our SS about it he advised that the flashing has been installed 2 brick courses too high and is working on a solution. We are trying to find out what sort of solution would be acceptable as we don't want issues coming up later on with water run off etc Can anyone provide any advice? Thanks so much! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You should check your detail drawings, it may show downpipe within brick pier. 14 14671 Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 3556 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 12630 |
