Browse Forums Building A New House Re: Water pooling against new slab 2Dec 29, 2016 7:29 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Water pooling against new slab 4Dec 29, 2016 10:35 am Is the slope the natural level of the land or something the builder has done so far? If it's the natural level unless you stipulated in the contract that the builder was to rectify it prior to the build starting I would imagine they wouldn't do it off their own back? Our land sloped down to the west side of our block towards the house so we have rectified that after handover with landscaping and drainage to the garage perimeter. We are on sand so pooling wasn't an issue prior to this. Re: Water pooling against new slab 5Dec 29, 2016 2:22 pm Being on sand is a different set of circumstances and water won't dam as it can with clay soils that expand and contract so much that slab heave may occur. Water in all cases should be directed away from slab not to and under slabs. NCC dictates this. Re: Water pooling against new slab 6Dec 29, 2016 3:15 pm Good posts Goody (and B-E). bpglendale, you are quite possibly/probably on Bay of Biscay and have good reason for concern. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Water pooling against new slab 7Dec 29, 2016 6:54 pm Looks like you've built on fill judging by your neighbour'd boubdary. I had a similar situation at slab stage however shortly after they connected all the drainage pipes and this was no longer an issue. Not sure if this is the case for you. They will also batter the soil/fill to fall away before handover. My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Water pooling against new slab 8Dec 29, 2016 7:29 pm jasonwg They will also batter the soil/fill to fall away before handover. It is suppose to be done at the start of construction. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 7333 6 5477 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 6200 |
