Browse Forums Building Standards; Getting It Right! Re: [Urgent] Advise please - Weep hole 25Jul 31, 2016 12:03 pm Mpang Just for anyone that is curious of the outcome, quoting their response: The purpose of the weep holes is to remove moisture egress and allow water to escape should there be a “catastrophe” where the home floods and the cavities fill with water. It doesn't require a catastrophic event to flood into the weep holes if the weep holes are near to or below the finished surface level. Low weep holes also provide termite access. Mpang Just for anyone that is curious of the outcome, quoting their response: The weep holes being at footing level allows the water to escape instantly rather than installing them at 0c and the cavity having to fill up before the water escapes. Yes, the bottom of the weep holes should be at footing level and they are but that is not the point under discussion. The ground levels are required to be 150mm below the DPC (bottom of weep holes) and that is not the case here. "The height of a DPC, or flashing serving as a DPC, (see Figure 3.3.4.1), must be not less than— (i) 150 mm above the adjacent ground level; or (ii) 75 mm above the finished surface level of adjacent paved, concreted or landscaped areas that slope away from the wall" Mpang Just for anyone that is curious of the outcome, quoting their response: The weep holes will still be fit for purpose, should you landscape over them and is standard industry practise. This is simply yet another example of a regional non compliant practice becoming endemic and the regulators remaining inactive because of the enormity of the practice. This has happened before with regulators ignoring other non conforming widespread practices, some of those practices leading to "catastrophic" damage and innocent home owners unable to make insurance claims totalling many, many millions of dollars because the cause of the damage was non compliance. The thread below may interest those who are likewise interested in this subject. "Still fit for purpose"? Hardly!!! viewtopic.php?f=1&t=81377 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: [Urgent] Advise please - Weep hole 26Jul 31, 2016 6:32 pm The purpose of weep holes is for cavity ventilation and drainage. Weepholes must not be obstructed and must be above adjacent external surfaces so that DPC "typically at bottom of weep holes" is not compromised. In a situation where weep holes are not functioning properly and there is permanent dampness , it will increase termite risk or be conducive to fomation of mould "both are undersirable". Typically builders will not pay to remove excess soil from level sites and will spread it around instead leading to ground levels too high that do not comply with BCA. With no one checking , Voila! Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you… 1 7584 I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible 5 6169 You are correct. Just read through all the ncc rules and 75mm is the minimum requirement for me. 4 11960 |
